autocross tire pressure?
I have an 03-996-C4S with 18 factory wheels, 225/40 front and 295/30 rear, with Bridgestone S02A's.
For street driving I have been using the factory recommended 36 front and 44 rear. For autocrossing how much higher should I increase the pressure? the maximum for my S02A's is 44 front and 50 rear.Thanks in advance for the recommendations.
To answer your question...I think you might want to go the other way. Lower your pressure not raise it. An example...last season with my 944, recommended tire pressure is 29F/36R. I was typically running 29F/32R and had great results.
I would recommend starting from the factory recommendations. See how the car behaves and lower it in 1-2 lbs. increments (front, rear, or both) until you get your desired result.
I have pretty similar tire sizes to you. For street tires, I like about 40 hot all around. Usually I run 38 in the front and 39 in the rear cold to start. Typical AX runs don't warm up my tires enough to change the pressure drastically.
I'd also suggest finding someone else running a similar car and ask them. People are generally pretty friendly at an ax, especially with beginners.
Jon
You will want to add a few psi (say about 5) to get started and then use the shoe polish to figure out if you need to go up or down from there.
Have fun!
do a couple of laps to get your tires hot, get off the track, take a measurement and put down some shoe polish, and go back out for 1 hard lap.
if you didnt scrub off any polish, take it down a notch, if you are scrubbing off polish, pump it back up.
also, for Auto-X purposes, you usualy get 1 lap at a time, which means your tires dont get to their optimum temperatures right away, some tires (like an RA1) get really sticky only after a couple of laps on a full blown track.
for that then you would ahve to compensate at an AX event by pumping more air.
having said that, assuming that your suspension is done up well enough, the best way to figure out your tire pressures is to you a pyrometer on the inside outside and middle of the tire the moment you get off the track on all 4 tires, this however requires quick hands and 4 people
take the car to a big OPEN parking lot.
mark the tires in 4 spots along the edge of the shoulder with the shoe polish.
make sure your pressures are where the factory tells you.
mark off a big circle with cones if you have some... say 50-100ft diameter.
do a couple of laps in one direction and then get out and measure the tire pressures on the inside edge, center and outside edge as well as check to see where the shoe polish has worn off... this is on the outside tires you were just cornering on.
the ideal is to find a balance between even temps across the tire and even wear at the shoulder. you want to use all of the tread on the shoulder WITHOUT rolling over onto the side wall.
if you are on the side wall you need more pressure.
if you are not all the way onto the shoulder you need less pressure. you can also use this to dial in your camber settings if you can adjust for it.
