Anyone Tried Adjusting Subframe Position?
I tried moving the rear subframe today, loosen all the bolts I thought might be useful, and at best might have shifted the subframe to the driver side 1-2mm. Not much, and perhaps my skill is the limiting factor. Will try the front in a few days, but just wanted to toss the question out into the group. Thanks for any feedback!
Thanks for your response.
Anyway, hoping perhaps someone with some technical experience in the suspension can chime in.
Have you checked the other usual suspects for inconsistent settings?
ride height
tire pressure
shim stack height variance
eccentric bolt runout & position
alignment done with drivers weight
swaybar preload
For this level of specificity you're probably in the wrong forum, maybe even the wrong site (Try the Racing & Drivers Education Forum or Cup car forum here)
Thanks everyone who have tried to contribute info. Appreciate it and hopefully some more info will be added to this thread that may help others too.
btw, I think the 718 GT4 is an awesome vehicle. Probably best purist driver I've owned. Bought it for not only the wonderful driving experience, but also the fairly adjustable suspension. Not quite as much as my C6 Z06, but much more than most BMWs.
It does certainly appear that the limited responses thus far indicates at best a very small gain from trying to move the rear subframe. On the order of 0.1 deg camber each side. I'll update if I gain more info.
I'm not familiar with the Porsche subframes, but my previous experience with Miatas is that the mounting points have at least half of them being "centering" style which has only micro amount of capability of movement. That's obviously on purpose to make everything easy. I'd bet our subframe mounting is the same.
Ron
Ron
Hope to say hi to you sometime this season. Perhaps Crows or Packwood
Don
After the subframe shift, and the pic attached looks a bit crazy, but I thought in terms of like dental braces, keep some positive tension on the left, persuade the subframe to shift toward the driver side with lever, BFH knocking on a 2x4 at several points of the subframe. Got the rear numbers to 1.8 deg left/1.85 deg right, a full 1/16" toe-in per side or 1/8" total toe-in. Pretty much my goal for toe. FWIW, I think the subframe shift made the L/R rear eccentric bolts (for camber and toe) closer to each other in the final positions, not exactly the same though. I'm happy with the results, and perhaps not a procedure worth the effort for most, but for me and my access to equipment, it was totally worth it. btw, I shifted the front also, and noticed a more balanced front alignment, gaining a slight amount of camber on the left, giving up a bit of adjustment on the right (it had plenty to give).
Hope I understood your question!
