More exhaust tips - Kline carbon?
Am on 3rd set of OEM tips and once again they have started pitting.
May well pursue yet another Ex warranty claim, but considering alternatives and do not want round tips in the unique opening on the turbo.
Anyone got the Kline carbon tails and if so, views? Particularly the robustness of them to the extreme temps etc...
Pictures would be super too... thanks.
Get the OEM tips coated in black high temp ceramic paint.
I tried with two OPCs who advised me that they were not covered!!
I am on the 2nd gen Kline CF tips. It's better design than the first one as the prev one had the CF layer attached to the metal skin of the tips directly, thus would yellow over time due to the heat. In my case, within 6 months.
The revised version (2nd gen) has the CF layer levitated from the metal exhaust tip skin, similar to the SpeedArt CF tips, thus minimizing the heat effect on the CF; however, the edge of the CF layer is wrapped around or comes into contact with the edge of the exhaust tips, thus, I am not sure how long this will last before it will yellow again. I've had the revised version for less than 500 miles thus far, and no yellowing yet. We'll see.
Second set was replaced under UK extended warranty - initially there was a refusal as there is an exclusion stating "Optical and acoustic defects with no impact upon functionality." but I persisted and they were done after Porsche GB agreed to do so as an "act of goodwill".
The long story:
The area that fails in each case is that inside edge of the chrome plating - as supplied by the factory there is a black painted inner edge (which looks pretty shyte) - probably there to disguise the anticipated pitting but it seems to exacerbate it - and as this is cleaned repeatedly it comes off revealing the ruined finish.
Also the heat-cycled paint permanently stains the underlying chrome yellow, and so you end up re-masking the line and spraying it occasionally with VHT black to keep it tidy.
On the first set I actually polished through the chrome on one tip to the nickel/copper plate beneath just using Autosol as recommended by the OPC. So maybe that set was faulty.
The second set just pitted and looked scruffy - and again I had to repaint the black bit which got larger as the pitted area extended.
The third set look a lot less bad - when they were supplied I stripped the black paint off and used GTechniq nano wheel protector on them. Believe it or not this withstands the temp fairly well and can be frequently re-applied. However, it's not a final solution as this third set are now failing.
I'm investigating alternatives as I fear I will not get a fourth set under warranty!
Kline said there is a 4-year warranty which sounds promising.
Any chance of a picture?
Here's the updated Kline CF tip
At the rate Porsche OEM CF has delaminated on my dashboard (5 times in 95K miles), I find that a brave move of Kline.
Anyway, Techart for me. No problems and cleans up easily.
Has anyone else been able to have their OEM 997.2 Turbo tips replaced under warranty? I'm down to the nickel/copper plate too trying to make them look good.
I'm covered by a 2 year/50,000 mile CPO warranty now.
Thanks in advance!
Thanks in advance!
Looking at the top down view, it appears that there's a line about 3/8" from the outside edge - is this some sort of join?
I think that they look very smart, and like them enough to be 'wanting' them, but I am indeed smarting even more about longevity of carbon fibre and hot exhaust - it just seems subjectively a really odd materials choice for this duty.
A bit like vinyl wrapping a cardboard coffee pot - "Don't worry - the vinyl should keep the cardboard dry"...
I suppose I'm just too suspicious after three sets of OEM and one set of (failed) aftermarket metal tips.
Yes, it appears to be some sort of join. This is where I am a bit leery about; as it's the place where the CF wraps around and comes in contact with the edge of the tip. Ideally, this area should also be levitated above the stainless steel tip (a double barrel, if you will) to provide a space of air to minimize heat effect on the CF material. I truly think SpeedArt's CF tips for the 997.1/.2 Turbos got it right, but unfortunately, the design of the quad tips muffles the noise and diminishes the wail of the turbo boxer in the upper rpm, in my experience.
Agree completely - maybe a completely annular design would leave the CF too unsupported and vulnerable to damage.
I thought the SpeedART tips for the Gen 2 turbo were single ones, like the GT2? And also stainless, not carbon? From their UK website...
- They were replaced without quibble under OEM warranty - so why a different behaviour under Extended Warranty?
- It is not an optical 'defect' or 'wear and tear' - neither something caused by wear from debris or other road matter. (e.g. stone chips), nor an acceptable tolerance of defect present at time of manufacture (e.g. missing pixel in PCM)
- It is a progressive failure of the material of construction to meet the requirements for which it was specified under normal operation of the vehicle.
However, in the world of extended/CPO warranty, no doubt YMMV.
My bad, it's the Cargraphics CF tips that I am thinking of.
http://vrechise.com/getimage.php?i=CARP97ERKEV_3.jpg
Some one pointed this out to me a while back and I may be into making a set of tips for the Kline exhausts when time permits. I have a full 3" from them and no cats but using the factory tips to keep the stealth look, but not thinking about the change down to 2.1" at the exit so they can fit the factory tips.. I know so me will argue this makes zero difference but it actually does in an exhaust system. having a 3" wide open system then down to 2.1" is quite a bit of restriction at the tips. Im looking at cutting back on the pipes before the crimp and having tips made to clamp on the outside diameter of the 3" for the exit.
