M97 Engine Dimensions
Newbie to this forum, but it seems like this might be a good place to get the answer to my question regarding the M97. I'm looking for the rough dimensions of the engine. I'm most interested in the height if anyone can help. Overall, block, from the crank, etc. As many of those numbers as possible. Ballpark estimates are also welcomed. Thanks in advance.
The turbine housings are the widest point on this engine 46.0"
Cam housing with coilpacks installed is 33.0"
The rear oil tank drain plug to the top of the oil tank is 23" If you remove the engine oil tank the plenum is the next tallest measurement point
The engine crankshaft pulley bolt to rear main seal is 21" This is with no flywheel.
Disclaimer>> I have taken these measurement directly from an engine.
