Do you have to use the rear brake backing plate?
Just took my car in due to a "rattle". They discovered the rear pads were shaking (could be moved up and down). These are pagid pads. The same ones I've been using for the last 3 years on the track. Have never had a problem. The guy at the dealer service said that the reason is because the backing plates have been removed (which I did 3 years ago yet never had a problem). This really doesn't make sense to me. Are the backing plates (dampeners) really necessary to hold the pads in place?
I don't use them, due to using Pagids and not being able to fit them in as the pads were too thick when new. I don't have any issues with rattles.
That looks rather strange. Do both sides have the issue? Could be uneven wear on the pad.
Quite, they can't be!
The dampers are just that - vibration dampers, not anti-rattle clips/springs.
Wonder if you have the right pads? GT3 ones are similar but apparently slightly smaller but thicker - taking Textar as an example.
(Thicker - might explain why some can't re-use the dampers!)
