Recommended Mods for new to me 997.1 TT?
5th Gear
Had about eight track days, what would be a good alignment setting? (still a newbie at this.)
Thanks!
No, I did not request for those setting. Told the dealer I am a newbie for track days. They setup accordingly. Not sure if I am reading the alignment setting correct; attached is the alignment readout.
Thanks!
Thanks!
I would recommend increasing front camber to -1.2(max on oem setup) Adding a bit of toe out on front (negative x.0x) reducing negative camber on rear to -1.7-1.8. Again this is given you're on stock supension.
Redwood city? I was at Alices yesterday. cheers.
5th Gear
You're reading it correctly. Are you on oem supsension? lowered?
The car is lowered with RSS Toe Steer Kit, Rear Link Kit and Sway Bars.
Thanks for the alignment info... can you recommend a place for tires and alignment? (For my other cars, been using General Tires at Redwood City)
Went on a run and passed Alices just this morning. ( maybe we can meet up sometime)
A few recomendaions for mounting tires and alignment.
http://www.brrperformance.com/index.php
http://www.tcdesignfab.com/
I've had great success previously with NT01s and good success with RS3s, but
none of my WB 993 wheels will fit over PCCBs and I don't want to invest in a set of sticky 19's right now.
sigh.
