Review.. "Function First" tranny bushing
I had the bushings installed last week and today is the first time I have driven the car at speed on a twisty road.
I'm really impressed! The shifts are smother. The car is tight with less roll. The sound (to me) is awesome. It's very "viceral". At cruising speed you don't get any sound or vibration. But going through the lower gears at WOT it's very noticeable.. Especially first gear. I can't explain why but when you accelerate in first gear the car almost feels normally aspirated..
I drove on a road that I know very well and I couldn't believe how much better the car felt. I'm by no means a great driver but I can drive fast comfortably. When hit the apex the car reacted so much better out of the corner..Just felt more "Planted"..
I know my car so well and I trust it..But now I can trust it even more!
I highly recommend this mod to anyone who like to drive in the canyons or does and occasional track day. If you just drive your car on Sunday and never get on the limit then mod this would be pointless
I have the stiffer version..
Just wanted to pass this along to anyone who has been thinking of installing these..
I just installed the yellow street version of these. The change is not as dramatic as Phillip noted but the improvement is noticeable. The drive train is better located and every thing is tighter. What I like about it most is the enhanced mechanical noise transmitted to the cabin, and I mean that in a positive way, more exhaust noise (mines stock) and more mechanical noise. Cruising it's not noticeable but when you nail it, it just sounds better.
Tom, I installed mine when I had my Sachs 2.5 clutch installed so no cost beyond the part for me. The installation doesn't look to complicated on it's own, probably takes an hour or so. I was considering the motor mounts as well but I could get them in time and it has allowed me to evaluate the impact of the trans mount on it's own. I think I may still do the engine mounts in the future. I'm on the fence on an exhaust, given the chickensh*t rules in Calif it's not really legal. If I do install an exhaust I'll probably do the engine mounts at the same time.
BTW, little or no compromises with the Sachs clutch. It may grab slight more at launch, but that may be the result of a brand new disc as much as the clutch change and it seems to have softened a bit after a couple of hundred miles. My car is currently stock but it nice to know I won't have to screw around with the clutch in the future should I decide to "upgrade".
Tom, I installed mine when I had my Sachs 2.5 clutch installed so no cost beyond the part for me. The installation doesn't look to complicated on it's own, probably takes an hour or so. I was considering the motor mounts as well but I could get them in time and it has allowed me to evaluate the impact of the trans mount on it's own. I think I may still do the engine mounts in the future. I'm on the fence on an exhaust, given the chickensh*t rules in Calif it's not really legal. If I do install an exhaust I'll probably do the engine mounts at the same time. BTW, little or no compromises with the Sachs clutch. It may grab slight more at launch, but that may be the result of a brand new disc as much as the clutch change and it seems to have softened a bit after a couple of hundred miles. My car is currently stock but it nice to know I won't have to screw around with the clutch in the future should I decide to "upgrade".
Why are you worried about exhaust. You'll have no problems with smog.
FYI your car is no longer stock
Like Bryan said the noise under acceleration is "mechanical". It's really quite cool.
And no my transmission bushing was absolutely fine. You just don't realize how much flex is happening with the stock set up until you stiffen it up..
If you drove with me you would feel it. The car is way more "accurate" without that flex..
Install will be an hour labor. So I guess it depends on where you have it done.. I paid $150 for the install and trouble shooting the squeak in my shifter.
Thanks and I agree with your approach. Take small steps to enjoy and evaluate each mod. Give the clutch a few more hundred miles to seat itself. I still think the hydraulic assist sucks!
I know it sounds like I'm exagerating but i'm not. It really makes a big difference.
Yeah and no one rides with me anyway lol! So i like the noise!
My passenger seat looks new!
Bryan, perhaps one day you can drive my car and see the difference between the two variants..
Great review by the way.. You described it perfectly..
Thread revival, how are everyone's thoughts on this to date? My clutch is done and figured this may be something I want to do while it's out? Guess if also need to decide on the stiffer or less of the two as well. Thoughts from owners, please chime in.
I have the softer yellow street version and am happy with it. Of course I've only experienced my version so I can't compare. It's a matter of degree, the mount is stiffened resulting in less movement of the trans/engine and a big plus for me, more mechanical noise transmitted into the cabin. The car just sounds better, more purposeful. Perhaps Phillip can chime in, he has the stiffer version (maybe I should be jealous)......
