997 Turbo Forum 2005-2012
Swap "turbo" emblem
Old 04-26-2013, 03:34 PM
TT Gasman
TT Gasman's Avatar
What adhesives are you all using to replace the emblem?
Old 04-26-2013, 05:24 PM
svb
svb's Avatar
man I wish I could get my duc to fit into my garage like that
Old 04-26-2013, 09:25 PM
aa909
aa909's Avatar
They are not removing the emblem so no adhesive required. The plasti dip is sprayed right on the emblem while still on the car and when dry you peel off the excess. No mess
Old 04-26-2013, 11:27 PM
TT Surgeon
TT Surgeon's Avatar
Where do u get this stuff?
Old 04-26-2013, 11:45 PM
nota_troll
nota_troll's Avatar
https://www.dipyourcar.com/home.php
Old 04-27-2013, 12:05 AM
ilko
Agent Orange
ilko's Avatar
Or Home Depot if you're only looking for black. I have an assortment of colors at home. I plasti-dipped the centers of these wheels a year or so ago using gray followed by silver metalizer:
Old 04-27-2013, 01:40 AM
spaceman_spiff
spaceman_spiff's Avatar
I picked mine up at Lowe's. it was just under $6/bottle. I also picked up a can of white to do the rims on my Ducati 999.
Old 04-27-2013, 01:43 AM
spaceman_spiff
You should see behind the car, i have ~3.5 sets of tires and about 4 feet between them and the car!
Old 04-27-2013, 11:58 AM
aa909
aa909's Avatar
Now you just need to upgrade your signature with a pic of the car with the new back "turbo"
Old 04-29-2013, 01:08 AM
turbojohn
turbojohn's Avatar
I want to remove my turbo emblem. Earlier I remember folks saying to use hair dryer and heat emblem while using dental floss to carefully try to pull emblem off slowly. I guess you keep pouring on the heat until dental floss begins to move. Correct? Question if done this way, can all traces be removed, meaning no damage to paint/clearcoat?
Old 04-29-2013, 01:12 AM
spaceman_spiff
When I did this on previous vehicles, I heated up for a moment or so. Then I used the floss like I was doing between my teeth. So basically you are using the floss to cut thru the adhesive. Afterwards use goo gone to remove any leftover residue.
Hope this helps.
Old 05-02-2013, 02:35 PM
a_wlee
a_wlee's Avatar
How did you take the emblem off, any help will be appreciated
Old 05-02-2013, 03:54 PM
spaceman_spiff
To get my emblem black I did NOT remove the emblem. The plastidip used just peeled right off of the car.
Old 05-02-2013, 07:16 PM
a_wlee
a_wlee's Avatar
So spray on, let dry and peal away or did u tape it off?
Old 05-02-2013, 08:48 PM
spaceman_spiff
I cleaned the surface, and then taped off with multiple trash bags and blue (and some green) painters tape.
I then sprayed the black on with 4 coats waiting approximately 35 to 45 minutes between coats.
I then allowed it to cure overnight (about 10 hours) before peeling. When I grabbed the far right part of the trash bag and pulled, everything but the letters came right off. I used a plastic toothpick to lightly scratch inside of the "b" and "o" in the crease until I could wedge the toothpick under the coating to peel the rest off.
Here are 2 pics of the process:
Quick Reply: Swap "turbo" emblem
