The official Bilstein PASM Thread
#48
Well... I have had these on my car for about 8 months on the softest setting with GT3 alignment. The drop is around 10mm - very subtle.
The ride is definitely firmer than stock but MUCH better than the Sport mode on stock suspension. I really don't think it's that bad.
Having said that, I may try stock shocks and Techart springs in a few months. Just to see how they compare.
#49
Is the novelty starting to wear thin then, or are the seat springs wearing out?
Btw what's the wife say about the ride of the coil overs?
#50
My wife expected the "car to be rough". Not that I care but no complaints from any passengers.
I am happy with them for now until I see a failure.
#52
I've read too many threads on Bilsteins and it's scary but I enjoy mine. I actually wish they were stiffer, even in sport mode.
Yep with those B/Steins I couldn't see too many prepared to do that exercise twice and keep a straight face. Stock is an absolute dream in comparison. I'm sharing that same loveee every day i drive her. GT3 which has basically the same set up is so resolved, so it just goes to show what Porsche sets as a minimum standard for that car. Not to say i'd be brave enough to DD a GT3 either but heck you've got to ask yourself how on earth did Bilstein manage to make such a mess out of its aftermarket product.... Incredible!!! You'd think it would be better given the phenomenal heads up Porsche has given them. I sure hope they're sending poor old cannga a case of scotch every xmas....and anyone else prepared to live with it or sing its praises. They sure as hell deserve it....and then some.
#54
Paul,
Great to hear from you! The stock suspension is a little too soft, so I am trying different things here and there to find the perfect balance between handling and drivability. The Bilsteins are OK. They are much better than the stock suspension in Sport mode. Not as jarring, so I wouldn't trash it for no reason. Having said that, I will try stock shocks and Techart springs soon. I would like it to be a bit softer than the current coilover system and wouldn't mind a little more play between front and rear axle upon acceleration.
#55
Having just H&R on my car on stock suspension I can tell you you will be impressed. Would love to hear your opinion once done, I think it will be an eye opener!
#56
Yes, remember when champion track tested bilsteins vs hr springs, the springs were considerably faster.
My own track experience w bilsteins vs gmg was very unfavorable for the bilsteins.
What would be interesting would be the new tpc module with an otherwise stock suspension.
#58
The shocks in our TTs have valves that open and close when you go from normal to sports mode. So when you press sports mode the PASM actuates the internal valves in the shock absorber and closes them causing the shocks to stiffen. It's basically a hydraulic system that is either in normal mode or sports mode
IIRC The TPC system is an active dynamic system that modulates these valves depending on the motion of the car. So for example if you are cornering hard to the right then the system may stiffen the left shocks more while softening the right side. if you brake hard then the front shocks may stiffen more etc. People correct me if I'm totally wrong here.
BMW has an active steering system that does something similar but I think it incorporates some other mechanisms as well
While the TPC system seems very interesting my primary concern is how it impacts the longevity of the shocks. I don't know if the little valves inside the shock absorbers weren't designed for this kind of dynamic system with continuous actuation. I fear the TPC system may shorten the life of these valves and I'd like to see some long term testing first.
#59
Sure is a pleasure in fact a monumental understatement if you were comparing against those B/S.
Paul,
#60
The aftermarket Bilsteins lull you into a false sense of security. Mine were great and problem free for almost 2 years then I got the fatal PASM failure, and that was that, one of the wires had gone bad on the front. To their credit Bilstein repaired the shock under warranty. Apparently a common failure. But I got rid of them, I can't have that shiit on a 150k car, I demand reliability.
