Did the LED's
Here is a pic of the LED's in front.. The driving light and the side marker.. I thought the fog light bulbs came with the kit but it does not. i have ordered those and will install next week. I did the dome light and door lights and license plate lights.. I left the stock bulb in the engine compartment because the LED shuts off after a few seconds..
It looks really nice...
nice job. I just got the LED fogs and license plate lights today and will probably install them this weekend along with a carbon fiber license plate frame I picked up on ebay.
Sweet. If your doing the interior lights as well be very careful with the door light lens.. Even though I was very careful in removing them I managed to break the tab off of one of them. Got a new one today.. $12 bucks.
Also be careful with the dome when you separate the lens to get to the bulbs..That can break easily as well..
Most of the "how to's" are in your owners manual.. The fogs instructions are on Maxspeeds website..
Looking good. Did mine as well.
A few notes. Bulb for engine bay was constantly dim, no solution yet.
License plate bulbs- on my thrid set, 1st set would shutdown after 15 minutes, not enough resistance, , 2nd set would flash on quickly and never come back on again, too much resistance. I don't know if these bulbs have thermistors but wrong values could cause the isssue as well. On 3rd set now no issues to date.
Front luggage bulb will not through CEL but will show up in PIWIS as a bulb out.
Overall I'm very impressed especially with the interior bulbs, and as Phillip mentioned be careful and patient, I found that the manual is not always your best friend especially with removing the side markers(Art knows this
Oh and Maxspeed customer service is exceptional.
Looks good...
I installed the driving light and fogs a few days ago, waiting on the sidemarkers. Will post some pics when everything is installed
One thing I would say is if you need functional fogs (i.e. have occasional fog in your area) these may not be the way to go as there is definitely less light projection with the LEDs. (May consider HID Fog conversion)
Some pics I took this evening...
http://www.suncoastparts.com/product...de=997ttlights
Zero, looks great. I'm installing my Fog LEDs tomorrow. Did you have to get the car up on ramps to complete the swap. BTW your license plate frame looks terrible, I mean awful, it really cheapens the entire look of the car. you may want to replace it with one that says New York Yankees ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
phillip, I just did my license plate LEDs and I couldn't get them to work, tried reversing the polarity and nothing. then I realized I had the LED light point up, not down
. corrected that it they look great. Embarrassing little error on my part that cost me 10 minutes of wasted time but thought I'd share just incase you made the same silly error as me
. corrected that it they look great. Embarrassing little error on my part that cost me 10 minutes of wasted time but thought I'd share just incase you made the same silly error as me![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
They Suncoast solution sounds like the way to go...
License plate frame will never come off or be replaced......plus I would loose 10 hp
They look great. Only down side is cost and if one of the LEDs goes out then the whole thing needs to be replaced as it is one sealed unit.
I used a floor jack, but yea you need to get the front end up some how. Also, the connector on the LED fogs is slightly larger than the connector on the car so I needed to use some pliers to make the car connector larger.
License plate frame will never come off or be replaced......plus I would loose 10 hp![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
and j/k on the license plate cover, you gotta support your team
