Replaced my PCM 2.1 with Pioneer Nav System
#47
I would not recommend front sensors for daily use. The car sits too low and they were constantly activating (tone). I had a kill switch installed that deactivated the front sensors during normal driving. When I approached a curb or other barrier I flipped the hidden toggle switch located under the dash "on" to ensure I wouldn't run-up on it. They worked well in that situation. I think it was $250 to have them installed.
#48
that's silly. Put a $1000 unit in your car to bring it to the next decade and it depreciates the car? Keep the OEM stereo and if the next owner wants to go back to 2007 tech, they are more than welcome
#49
This seems strange. What brand sensor did you use?
#50
I don't know if the 997 is lower nor do I recall the brand. The sensors were installed in the grill (vs. higher on a bumper) which caused them to sense too much of the road resulting in false activations. The installer warned me this might happen, perhaps I should have listened.
#51
But something else you could try is the curb alert system. It's very simple and plugs into the battery. I used it on my shelby. Worked good. But it's only useful for detecting impact directly in front of you, so literally front parking curbs. Won't go off for things at the side of your car.
#52
Recently had the Pioneer Avic Nex 8000 installed in my '08.
Also downloaded the Apple Car Play firmware.
Appreciating the upgrades compared to the PCM 2.1 and personally, I think the look is seamless and appears OEM.
#53
That Pioneer system is supposed to be awesome, loved the videos and reviews with apple play.
Did you have someone install it? what did it run? I hope you picked the unit up off Amazon... it goes for 1/2 retail on there
#54
That's EXACTLY what i'm going to get. Well still on the fence with Alpine. Will tackle this battle once Spring is in full swing. Did you not look for the piano black trim to replace the silver/grey?
Purchased as package from Del Rey Customs in CA along with Sirius module and adapter to interface the car's Bose amp. Had install completed locally. Wasn't cheap.
#55
Rocky Mountain High
That trim piece looks nice and very OE...
#58
The install looks great. The screen is pretty busy though. Is there a more minimal setting that looks a little cleaner?
#59
After 30 seconds or so, the screen will revert to your chosen mode ie: radio, nav map, phone, etc.
BTW: the Porsche logo in the background is something I added and, apart from the stock backgrounds, you can add literally any background you want as a .jpg image.
Hope this helps.
Also, there's plenty of videos on YouTube about this unit if you want more info.
