'09 Turbo Cab, 2.5 yrs, TPMS gone crazy
Basic Sponsor
For the past few weeks, I've noticed that, although nothing has changed with air pressure or anything else, even avg temps, I get a TPMS warning EVERY time I get in the car.
I've verified the pressures are perfectly set where they have been for two years (checked with pro gauge, cold and warm), and nothing has changed. When I get the warning, it will tell me one tire is - 4. I will go through the reset and programming when stopped, drive 10 minutes or so, it will rebalance and clear.
Then when I stop to park, the warning pops back up, might be a different tire this time. And right before I stop, I check pressure on the readout on the car, and it's 30/34, as set, or within one lb of that.
Sensors are only 2.5 yrs old. Tires are fine, been checked twice. Pressures are fine too. I AM running lower than factory because the factory reco's are for full load, and I am not running with a passenger and luggage. So I have been running 30 in the front, 34 in the rear, and that works well for me.
Again, been same pressures for 2 yrs. Is there a TSB on the sensors? TSB on the internal TPMS computer?
Very frustrating. Suggestions appreciated.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
Basic Sponsor
Yes, avg life on sensor batteries is 5 yrs. I suspect it could be that, but seeing how the behavior is, I suspect it is more related to the 'receiver' rather than sensor.
Basic Sponsor
Not yet, but I've run that pressure for two years, no issues.
Based on temp readings, light load in vehicle, and other factors, that is a good number. But I'll probably bump it up tonight and see what happens.
It's just odd that things have been fine until recently.
I have had similar issues, problem is that the base line pressure (from which you get the -4) is too high IMHO..
What can help sometimes as you are talking about a little solenoid of some sort I guess, is inflate the tires to much higher (regular psi? 33-39 or something), drive a bit and deflate them to the desired level again.
Basic Sponsor
Yes, I boosted pressure cold on Friday to within 10% of factory full load numbers and the problem seemed to be eliminated, but need to do a bit more driving, then I may tweak the pressures down a bit more.
37 front/44 rear is just not needed on a non full load. Running 34/40 right now. Prefer a couple pounds lower...will test and report back.
Thanks for the tips.
2nd Gear
Replace all four
I was drivn insane with this issue...Nine weeks and seven experts to get to replace all of the sensors because they work as a set... 2007 turbo. Good luck
Similar Doug Sharpes' experience, my '07 Turbo also needed all sensors replaced a few weeks ago. Fortunately the guys at Champion fixed it the first time around. Apparently this is not that unusual.
Basic Sponsor
Bumped it the other night, and so far, no issues. We'll see what the weeks ahead bring.
Thanks for the input. Sensors appear to be fine (new at delivery Oct '09).
