997.1 Turbo wheel spacers
I got the 5 mm spacers on 20" RG5 Champion wheels front/rear with PSS10 Bilsteins.
Honestly I think 10mm would have been a better fit, they still sit slightly in - and actually looking to change up. So yeah - would recommend the 10mm.
You'll need longer lug bolts too.
You could do 6-7mm fronts and 13-15mm rear. You will need longer bolts. The stock rear offset is 51mm and my new wheels are 40 and there is still a bit of room to flush them.
I have 16 in the back, would have gone for 13. It is maybe a hairline outside the rear wells. On my to do list. I am not sure what factory sells, I think 17 but that is too big. And 10 is too small.
I was told to be careful of spacers because they could have the tendency to vibrate at higher speeds. Which, doesn't make sense to me at all. Has anyone heard this?
7 MM in Front and 15 MM in Rear is the perfect setup. Perfectly flush and no rubbing (assuming you have not lowered the car or changed suspension). Factory 997 Turbo Wheels and offsets are:
Front alloy wheels: 19x8.5" ET56
Wheel part number: POR 99736215605
Rear alloy wheels: 19x11" ET51
Wheel part number: POR 99736216202
DC
DC
