Denison out of the porsche ipod biz?
#31
Finding out what's wrong with the iPod not charging
You should go ahead and update to 2.05.
The iPod should never charge when the car is off. In your statement above, that seems to be what you are looking for. Not a good idea. It should be in sleep mode, and charge only when the car is 'on'...
Is that what you are doing?
I understand from another member (Atomic80) that his iPod charges for a couple of hours until fully charged, even after he removed his key.
And so, yes, that was what I was looking for, as my iPod kept dying on me when I don't drive the car for a day. I thought there was a problem with the charging mechanism.
From your reply however, now I learn that the iPod should go into sleep mode and only charge when the ignition is on? As I understand the charging time is not a programmable option, which means my unit is actually functioning properly?
If so, perhaps it is the old iPod's weak battery at fault then. Can I go out and buy a new iPod 5G or should I wait for the software upgrade? Don't think I can easily find a 4G. Or should I wait for the new software update.
Thanks again for helping me to pinpoint the problem Eric.
#32
Yes, that's correct. Mine charges until it's complete even after I remove the key. I've never had my iPod go dead on me before. Eric, have you tried seeing if you can find a refurbished 4G? I actually bought mine refurbished because they're just as good as a new one for less.
Chris, did you ever try having yours moved to the front? Maybe that will get yours to finally work! Mine hasn't been giving me any problems since the day I got it installed. It's been working beautifully. I believe firmly that as long as you get it installed properly by a qualified professional who actually knows what he's doing then it'll work fine.
The Porsche solution is at best a stopgap measure that works through the radio which IMHO is was a poor move by Porsche. They should have spent a little more R&D and gotten a better integrated system. Right now, IMHO the Dension _IS_ the best solution IMHO simply because of the way it works beautifully within the PCM. Yeah, you'll hear me say that until I'm blue in the face simply because I love the way it works. I've driven down to California and back with the iPod playing and couldn't be happier.
#34
Basic Sponsor
The 'shop' was recommended, but I do not personally know the guy who they use for installation. Just clarifying.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
#36
When was 2.05 released?
My iPod works great with the car, but I still need to unplug it overnight or it will be drained by the next morning. I am sure this is minor but it would be great to get the right updates downloaded so that I don't have to worry about unplugging it overnight.
Thanks,
TD
#37
Basic Sponsor
2.05 has been out for a while. The issue may be related to the ipod...if it's the 6th Generation, that is a known bug. Let me know what ipod you are using.
#39
Drained iPod issue
My problem could be a combination of the iPod and the Dension Gateway 500 unit. Any further suggestion Eric, and clarification on the charging part with the key removed?
#40
I had a Dension unit in my e39 m5 and it was the biggest piece of crap I have ever seen. It was so buggy. It even immoilized the car several times. Ripped it out and all was fine.
I would never buy their product again.
my .02.
my .02.
#42
Basic Sponsor
Was it the GW500 unit? Earlier non-MOST bus units were nothing like the technology of today.
If the reasoning above was applied to our Porsches, no one would drive them.
#43
It was about 2 years ago or less. Not sure but it was major junk. It plugged into the bus in place of the cd changer.
