The only downside to springs is front end scraping, but they all do that including stock. My experience with the Champion/H&R springs mirror Gene's impressions and those found in Excellence magazine. A noted improvement over stock, definitely worthwhile.
Both Techart and GMG springs are made by Eibach. The GMG units have a slightly higher spring rate than the Techarts
thanks ecolu, but what do you mean with the higher spring rate on gmg, is that better, or slightly lower is better, i cant decide between the 2. i am sure you will be biased towards the techart as you have then
oh annd whats the drop , is it 20 mm, just like the gmg?
as Chris said, the GMG springs are just a bit stiffer than the Techarts. I have never ridden on the GMG but expect them to be as satisfying as the Techarts
