feedback on rennworx wheels?
i'm probably going with rennworx wheels on my 997tt. they're forged, well priced (~$4k) and light.
does anyone have experience with them?
i'll confirm the specs tomorrow but i think they are:
- frt 19x8.5, 51mm offset, 20lbs
- rr 19x11, 55mm offset, 23lbs (update - correct offset is 47mm)
(update - spacers not needed) i'd like to see less offset in the rears and may have to run spacers.
how much do 10-15mm spacers weigh?
i'd like to see less offset in the rears and may have to run spacers. how much do 10-15mm spacers weigh?
Originally Posted by jhbrennan
I always thought the 5-spoke wheel was great looking...but check with the guys at Wheel Enhancement - I seem to remember Rennworx stopped production on on the 5-spoke - don't know about the other.
Originally Posted by eclou
The weight of the spacer is going to have a negligible effect since it is so close to the axis of rotation. I'd worry more about the weight of the tires you put on
updated specs
front
19x8.5, 51mm offset, ~20 lbs
rear
19x11, 47mm offset, ~23.5lbs (no spacers needed)
other
- accepts tpms
- comes with caps and accepts porsche oe
- std colors are silver or black; extra charge for other colors
- both styles are available
sounds like we can get a bit less offset if they have not been made yet.
btw, stock offsets are 56mm front and 51mm rear.
rear
other
- accepts tpms
front
rear
other
- accepts tpms
rear
other
- accepts tpms
qd5 specs
Are these the specs for the Neez QD5? The offsets you show are a little different than what their literature shows.
you reminded me that was some pdf file on eisenhaus' site with specs on the qd5. it seems to me the qd5 are more suited to narrow-body cars. their specs are:
19x8.5 +46mm offset ( probably a little too agressive for front wheels)
19x11 + 60mm offset (will need 10-16mm spacers for wide body fit)
front
rear
other
- accepts tpms
rear
other
- accepts tpms
rsr on 997c2
Originally Posted by RedRocket
I am seriously considering the rennworx RSR in black for my 997C2S. Would love to see pics of them on ! before I take the plunge.
