Any ECU flashes available for 997TT yet?
Saw on 6speedonline that Upsolute claim to have done 10 cars in the US .No details on their web site .
Good luck and let us know what happens if you go ahead.
Geoff
Geoff
Can you at least give us a hint and what might be expected?
HP? Cost?
Thanks..
-- When I had my S4 bi-turbo, i chose not to go with the "high" boost kit, instead I went with the medium boost kit and also upgraded all the hoses in the car. As a result, nothing blew.. At least while I owned it.
I think pumping the turbos to maximum capacity is a bad idea. I would be much more comfortable with a moderate boost as not to do long term damage to the car.
B
HP? Cost?
Thanks..
B
Rennlist Lifetime Member
Not really until it is finished. I get myself in trouble when I say things and they are not complete. Like any of the GIAC programming you will find no stone unturned nor any short cuts. These systems are nothing like the old system and involve several systems
It would be interesting to be able to control the electronically controlled multi-disk clutch so that you could, for instance, set it to 100% rear wheel drive for certain occasions.
Originally Posted by PorschePhD
Evo and myself are both tearing into our twins to get this accomplished. Very VERY soon.
I've had a close look at the stock turbos and i think they are good for 300hp each. So potentially with a properly tuned ECU flash, exhaust and cold air kit, i think we may conservatively see 550+ hp. Further, with bigger compressor wheel, i think we may be able to see 650+hp.
