Function First + Factory SSK or Numeric?
Gents,
Looking to do an upgrade soon of the shifter. I have a Factory SSK on my 09 Turbo with 72k miles on the clock(please don't shoot me for driving my car so much I am sorry I promise to buy a GT3 that I leave in a bubble). Basically looking for input from people who have done the Function First on their SSK, and those who have had the Numeric. If anyone has done both, thou are king and your opinion matters the most.
Josh
Josh
I have the Numeric shifter with a Function-First ****, stock cables, and am thrilled with the setup. The cliched "rifle bolt" feel. Pretty sure there are prior threads on this topic with photos etc.
If you want, there is a 90% chance I am buying the Numeric, I can sell you my factory OEM 997 SSK. Let me know what youre thinking in a PM.
The heavy shift **** I put on made a bigger overall impact on shifting feel, and I think the biggest upgrade will come when I have the Numeric cables installed in the near future. Since the lever floats freely in the frame, its effect on shifting feel is pretty much limited to its height IMO, as all of the actual "feel' is coming from the cables' interaction with the transmission. Function First cable ends would also probably go further in the "rifle bolt" department than simply the shifter.
I'm not sure the shifter alone will get what you're looking for. I installed the Numeric shifter a few weeks ago, and for me it's not the night-and-day improvement it seems to be for others. Outside of the car, my OEM shifter is smooth as butter and indistinguishable in feel from the Numeric. Dropping the height does mean you have to give it a little more effort, but other shifting qualities are pretty much the same.
There's a link at the bottom of the page on their site:
http://www.function-first.com/produc...ter-cable-ends
Looks pretty straightforward as long as you can get under the car.
I would go with the factory 997GT3 shifter for near perfection. The nice thing is that you can align your shifter/shift cable yourself with the tool that is included.
The throw is about 10 to 15% more than the 997SSK but near perfect (in my opinion)
Don't you basically get a GT3 shifter if you swap the plastic bushings to metal ones like with the FF kit? Except for the shorter throw, are there any other differences? Byt the way, thanks for the tip about adjusting the shift cables once in a while. Totally worth spending $4 on the tool.
Kevin, thanks for the info. I think I'm going for the FF kit and cable ends. Looks like a solid deal with the discount they are giving me. Will have my shop adjust the cables also.
