Another satisfied TPC DSC customer
I can't say enough about the value of this modification.
I have been messing with suspensions since my '86 16V Sirocco and this upgrade is the single most valuable upgrade I have ever invested in.
Anyone who goes this route, no matter whether on PSS9 coilovers (or some other active coilover system) or stock springs & shocks, will see a significant improvement out of the box AND give you the chance to change profiles with canned settings or even mess with it on your own.
I need sway bars now, like immediately, and maybe stiffer engine/trans mounts. This is all due to be able to drive the car closer to it's limits with a much better behaved suspension, no matter which setting.
Ed
Ed
it is probably the best mod for these cars that you can make!
Ed
Ed
Which made more of a difference? And how's the NVH on the 964RS mounts?
No added NVH with 964RS mounts that I could perceive. (Although I don't have a lot of seat time since installing and we added with new dampers and springs.)
GT2 bar was noticeable improvement - first thing I did.
964RS mounts added a small amount of mechanical and exhaust noise to the cabin and I like sitting in the car during a cold start. I'm running EP2 exhaust BTW...
I would do both again...
I may add the FF trans mount but not sure yet...I may be adding the UMW 4.0 kit clutch kit first.
Thanks for the tips. I was wondering which position on the bar, but you've already answered that.
964 RS mounts have been ordered. Look forward to trying those out.
Anybody run Tarett GT spec bars? Supposedly factory spec copies at only 60% of the price. Seems like a good deal.
Are the DSC module same for Carrera/S and Turbo/S? I bought one from my friend and installed on my Turbo, much more comfortable, but do get more side way body roll, so just want to make sure Ive installed the right one.
