Is it necessary to replace brake pads when replacing rotors?
I am replacing the rear rotors on my 997.1 TT. The pads still look good. Should pads and rotors be changed at the same time? I know there is a bedding process also so wondering if that will make a difference using old vs new pads.
Seems strange that you would need to replace the rotors and not the pads.. how many miles on the car?
Why do you think you need to replace the rotors?
When I inspected my rear brakes last year, I just replaced the pads, the rotors were still fine.. this was at 45K miles and most likely the original set of pads..
If it were me and I NEEDED to replace the rotors because they were grooved, under min thickness, etc. I would do the pads as well.. but thats just me..
Thanks for your input. Car is going on 46K miles and the wear indicators, groove marks, a hair-line crack, and lip is enough to tell me I need to replace the rotors.
The previous owner seemed to have done a complete change up front but may have only changed out the pads in the back from what I can see.
I was just wondering if you or anyone else has had any negative experience by only changing out the rotors and not the pads.
BTW - if you're a Cowboys fan, GO COWBOYS. If you're not, GO COWBOYS !
OEM rear textar pad's are pretty cheap, less than $100 on Pelican. I'd suggest you do the job correctly and completely for such a minor cost difference.
I would change them, the grooves on the rotor could be on the pad also, which can lead to new grooves on a brand new rotors.
Good practice on any German car is to always replace pads and rotors together
Pads not that expensive. If it were my car I'd just replace the pads.
While you can get away with it, as others have already said, replacing is the best practice.
Since you will already have the calipers off, it will be a natural thing to replace the pads and for the cost, it really is a no brainer.
Ed
Ed
Well being a race car guy, we do this all the time because you wear pads and rotors out muh more often. Running new slotted rotors, if you have odd pad wear, it will flatten a pad out very quickly.
being the from sound of it, you have a street car, if it's under 50% wear of the pads I'd replace them but if over that, I wouldn't worry. Just make sure to bed the pads in
