Intermitent loss of boost
I just picked up the car from the shop where they they installed a new head unit and a K40. Battery disconnected. Question: I assume the custom 600HP Switzer tune would stick thru loss of power? When I left the car seemed sluggish. I got it out on the open road and it was definitely off. It was pulling maybe 7-10# boost and not making HP, then BOOM it felt like the other turbo kicked on and it would put you back in the seat, as usual. This 'full boost' only lasted 2-3 seconds before it was back to sluggish and 10# max boost. It felt to me like only 1 turbo was working and the other was on and off. I was able to repeat this behavior once more on the way home. I've been reading posts that suggest the turbo hoses might be loose or popped off? Where would I look first to see if it's the hoses? Is that the top or under the car? And other ideas?
Thanks! Dan
Thanks! Dan
Thanks! Dan
Thanks! Dan
Those are the places to start anyway.
Good luck,
DC
