Those who have added Dive Planes / Canards
Ngng. I think you miss the point of this. We are looking to actually raise the grip and limit threshold, not confirm to all that we can drive to the level that is there stock.
Any input re the rubber sizes appreciated.
Better shocks and stickier tires then are your solution
i was responding to the op's original question...should he install dive planes that he has sitting around, if they make a difference
back from business trip
therefore i have time to finish this project. I "should" complete this by next weekend.
I'll be doing some shakedown sessions in a few weeks and will report back.
Received 1,882 Likes
What is the rest of your aero setup?
Adding the Dive Planes will not be noticeable for any street driving. On track, it does help but its more a sum of parts thing than an individual fix. If you do not have a cup front lip yet, I would suggest doing that, and then add the dive planes.
If your goal is more front end grip, tires and suspension setup will be a more noticeable difference over dive planes.
Im running cup front lip, raised rear wing, 275 fronts, and a ton of suspension stuff and dive planes were the last thing i added. Fwiw the ones I added are larger than the 4.0 rs planes.
[QUOTE=ngng;13673122]
Start on Post #20
https://rennlist.com/forums/997-gt2-...hinking-2.html
Thanks for the guidance
For those running stock body panels on a 997.1 GT3, what sizes front track rubber can we go to and what is the matching rear size to keep abs working as intended in ?
1. 19" dia
2. 18' dia
Guidance appreciated.
personally, i guess i've never had an issue with front end grip that i couldn't change by modifying my driving style. what are people encountering?
1. 19" dia
2. 18' dia
Looking forward to trying this out soon
Its two piece design, the splitter tray mounts to the chasis, and the fence (what we call lip on the car now), mounts normally. There are 2 fence choices, a street fence, which doesnt hang down as far and allows a little more clearance at the front for the tray, and a track fence, which is more like the cup lip and hangs lower and sets the tray lower.
Thanks to all who replied!
Am already using the 997.1 Cup Lip (without vents), also has a gurney flap on the rear wing (AOA flat). Wouldn't mind having better turn in at the track or more front end stability at speed (it's ok currently).
Agree that the dive planes will prob work better with the .2 RS front fender extensions.
Maybe I should just install it and see how it feels. Will the 3M adhesive come off the xpel film easily if I decide to remove it subsequently?
her shann
her shann
her shann
her shann
Then tires and upgraded suspension components.
Not sure what canards add but I put them on my 997's.
FWIW I once added a cup splitter and gurney flap between sessions, only 20 minutes apart and completely forgot about it. The car was .4 secs faster on 1.20 Laptime but the last corner before the long straight is pretty crucial at about 100 MPH.
Like others said, all little but add up.
My fear is understeer at high speed, hence the front splitter i'm working on. BW should be a good test at T1/ Bust Stop / Riverside / Phil Hill. Slowing down into a turn should also give more confidence. One of my good friend, friend can do 1:53 in the new viper (NOT the ACR) - hoping i can match that time. Any pointers at BW? Only been their once.
Particually interested in T2 / T3 /T 4 feedback.
Riverside i need to grow a pair and stay WOT.
Thanks to all who replied! Am already using the 997.1 Cup Lip (without vents), also has a gurney flap on the rear wing (AOA flat). Wouldn't mind having better turn in at the track or more front end stability at speed (it's ok currently). Agree that the dive planes will prob work better with the .2 RS front fender extensions. Maybe I should just install it and see how it feels. Will the 3M adhesive come off the xpel film easily if I decide to remove it subsequently? her shann
