997 GT2/GT3 Forum 2005-2012
Track miles KILL the Mezger!
Old 05-07-2016, 12:34 PM
Spyerx
Spyerx's Avatar
Received 1,827 Likes on 1,112 Posts
Default Track miles KILL the Mezger!
Made you look? :-)
I like to enjoy my RS. Maintained well (over probably) but I like to drive it. I follow a really regimented maintenance schedule, oil/tranny every 4-6 days depending on miles on track, brake flush often, plugs at least yearly, etc... Well, car was due before next weekend 3-day GGR/Central coast event at button willow raceway.
I usually have the shop (BBI Autosport) do fluids, it's messy and their rates for the oil/tranny change are fair. Plus they look over the car. I'll do brakes, plugs, belts, and most other things myself. But since the car is now 9 years old with quite a few track miles (99% from me) I thought it would be good to give a deeper look at the motor. So since plugs were due, had the shop do a leakdown test.
Maintenance:
--oil/filter change - I use Torco SR5R
--Tranny fluid change - Tried Motul (I think 75-140 competition), felt good, as good as Delvac - Bill Rader suggests Motul these days... so we tried it, liked, will run again
--Compression / Leakdown test
--new plugs
--inspect: coils, belt, pulleys, PS pump, ac pump, brakes, suspension, etc...
--pull overrun codes
--pull blackstone sample of oil
Car got a clean bill of health. Leak down on all cylinders less than 1% and even across all cylinders. Compression (forget number) but all normal and consistent. Plugs look great (1 year old, 25 or 30 track days). No change in Overruns, that was my 5 type 1, she was a virgin. :-)
Oh one more thing... I've been running Race Technologies RE10 pads with Brembo Type III rotors, I just swapped rings before this last event and put new pads on. I went with the Type V front this time around. I like it. It has SLIGHTLY less bite than the Type III (but much longer life, it's a race car endurance rotor). However, with Type V in the rear it feels like the bias moved slightly to the rear and the car feels better on threshold braking. The ABS system seems to be happier. I'll have a more thorough report after Buttonwillow this next weekend. I'm super happy with the RT/Brembo setup, last a LONG time and very consistent.
So yeah... these motors if maintained are pretty damn stout!
Old 05-07-2016, 01:30 PM
shotor
shotor's Avatar
You did make me look.
Regular maintenance + regular exercise seems to be the key.
Old 05-07-2016, 01:46 PM
Fisher
Fisher's Avatar
Your detailed maintenance specifics such as replacement interval (time and/or usage), fluid manuf., etc. are very welcome.
Nice suspension parts. They will last forever when kept that clean.
Old 05-07-2016, 01:54 PM
Spyerx
Spyerx's Avatar
Originally Posted by grizfish
Nice suspension parts. Will last forever when you keep them that clean.
Is there a reason why you use that particular Bosch plug?
Car is actually filthy - 350 miles / 3 days on track at SMMR... car went right to shop for work.
Its the OEM plug spec, Bosch Y-5-DDC / 99917012990. The last set had blue markings on the ceramic. The new set has green. No idea why. I think porsche likes to get $35 each for their box with the same plug. Bosch is $9 each. Markings are identical, although the porsche plug has a brass colored electrical connection on the top of the plug.
Old 05-07-2016, 02:00 PM
Fisher
Fisher's Avatar
Pardon me. I went back and looked closer. They did not look like Porsche spec parts on my first look.
I use the same.
Old 05-07-2016, 04:57 PM
Liquid911
Liquid911's Avatar
Spyerx, in a nutshell what's the procedure to change plugs? Locally its around a $600 job including labour (from the OPC), thinking of doing it myself.
Old 05-07-2016, 05:04 PM
r6elmo
r6elmo's Avatar
made me look too - thought something had exploded. good write up - thanks!
Old 05-07-2016, 05:07 PM
Spyerx
Spyerx's Avatar
Jack up rear of car, pull heat shields on side of heads, remove coils, remove plugs, replace.If you have side mufflers it's tight, but can be done without removing. Without it's super easy, lots of room. Basic set of tools plus a plug socket is all thats needed.
If you're OK doing basic work this is a 2-3 hour job at most (and that's going SLOW) about $75 in parts of the OEM Bosch plugs.
You may want to consider a coil change if they are original, or at least inspect them insure they have no cracking.
Old 05-07-2016, 05:27 PM
Fisher
Fisher's Avatar
What he said ^^
Step-by-step.
https://rennlist.com/forums/997-gt2-...s-learned.html
Actually easier to change than the write-up led me to believe.
Just get under there. It will become obvious what needs to be done.
My personal experience on cars, trucks, and motorcycles is that most manufacturers specify to use 22 ft-lbs of torque on the plugs.
Nothing more than enough to barely crush the washers, which I don't recommend using more than once.
Old 05-07-2016, 06:48 PM
09redviper
09redviper's Avatar
What is the Milage of ur gt3 so far ?
Ur Porsche looks healthy.
Old 05-07-2016, 07:00 PM
Spyerx
Spyerx's Avatar
42k miles
Old 05-07-2016, 10:44 PM
spiller
spiller's Avatar
I thought my 30K Mezger with 2% leak down was good, now your 1% has made me feel bad!
Old 05-08-2016, 12:21 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,783 Likes on 2,371 Posts
as i said, that car is over the hill now and my $50k offer remains.
Old 05-08-2016, 07:47 AM
grrrmonster
grrrmonster's Avatar
I feel better now. Thought mine was the only one with 40k miles. Sick of hearing about garage queens on this forum with less than 15k miles
Old 05-08-2016, 12:11 PM
jasonturbo
jasonturbo's Avatar
I love your car Spyerx, and I love that you track it
Quick Reply: Track miles KILL the Mezger!
