Another coolant pipe story...
Wow, your blatant procrastination (failed to pin, and failed to run WW) put a lot of people at risk; including yourself, fellow drivers and track corner/safety workers. Not to mention the cleanup time required and LOST track time to those run groups after yours. Good on your for sharing, and hopefully wakes up others to do the proper thing.
In this case, it was intentional. Yes people take risks just by going out on track. Anything can happen. But it would just leaves a bad taste in my mouth intentionally put others at risk (until late spring of next year!) and having them unknowingly assume the potential risk and costs/damages.
Good on you for sharing though, great reminder for people to get the pipes pinned and otherwise not ignore safety. It's not just the pipes, make sure to also do other things pre-track such as check rotors and pads, etc.
I'm surprised we even have coolant pipe stories still, these cars came out back in 2007. I thought this was a thread necro-bump at first. Haha.
https://rennlist.com/forums/996-gt2-...l#post11271311
https://rennlist.com/forums/996-gt2-...l#post12504868
Anyone with the 996.2 engine case vs made in Spain cases had there fittings pop? Mine was a Spanish case. I know some of the cases for the 996.2 were made in Germany. I believe all 996.1 cases were all German. I'm n
>We know this is still an issue for 997.2 GT3's.
How do we know? I tried reading the long sticky on this and it seemed all the problems were with 997.1's.
The reputable show I use told me they have not had any problems with 997.2's.
I'm looking for hard evidence, examples of 997.2 failures.
I do a lot of tracking and do want to get this fixed if indeed it is a problem.
https://rennlist.com/forums/997-gt2-...l#post12451833
See the brownish stuff on the pipe connected to the hose? That is a fitting that popped.
Deny if you'd like but Porsche did not fix this. If you track get it fixed. Run water wetter at a minimum.
Any shop that sees these in volume has seen loose fittings and popped fittings on 2010+ models
The car was owned by a member, he can speak up if he wants to. Driven regularly. A few track days a year but nothing crazy. Treated well. Maintained well.
My thinking was very much in line with you till I saw that. Next time my car went in for semi-major work [Guard diff in my case], I had them pin my lines. Interestingly, the lines appeared and felt totally fine on my car. Making the expense even harder to justify. Oh well.
My Turbo started leaking from one of the three elbows off the oil cooler. Dropped the engine and found two fittings that were loose. Get it done. No point waiting for it to let go. And get the sharkwerks elbows while you're at it.
Having been behind 2 incidents, 1st thing I did when I bought my 997.1 was get the pipes welded. Accidents happen. But this is a known problem. Don't know why clubs don't insist GT3's have the pipes welded or pinned. Or run water.
My shop has welded the pipes on several GT3's. On mine the pipes had loosened up quite a bit and almost certainly would not have made it through another track season. They said they saw issues with the other GT3's, including coolant starting to seep and one GT3 with low miles that actually blew a pipe fitting while being tested on the dyno. Sad to say for Porsche engineering that these pipes are ticking time bombs.
