Austin-need help w Dirametric
Ran Cota yesterday. Still in Austin & have check engine/see work shop message. Can anyone help me check code before driving back to Houston tomm? Efgalliani@gmail.com. Thanks.
Go to harbor freight and get an inexpensive code reader. General codes can be read. Should give an idea of issue
May be tough finding someone open on a holiday. The cheap models from Autozone might work. I'm going to rent the pro durametric from this private individual in South Austin to turn off TPMS system.
http://austin.craigslist.org/pts/5109233482.html
Best of luck.
Best of luck.
Got him taken care of. Beautiful car!
The tx crew rules!
200 is normal on the street 220-240 is normal on the track. I was around 225-235 yesterday at COTA in my white 997.1 gt3
Interesting reading the latest Grassroots Magazines oil temps on the track oriented Camaro they just ran on a track. Quickly oil temps to 325 and even higher. They contacted Chevy's performance division, who said the oil temp is not actually measured, but rather the car's computer takes data and gives a "hypthetical" oil temp. The Mag said "why not just measure it, it is right there?" So Chevy put in a thyrister sender in the oil drain plug, and sure enough the temps really are high. They suggested changing to 15-50 oil for track time and pitting when the temps approach 300 degrees.
Sounds to me like the Camaro designers need to come up with better oil cooling.
Read in another mag, that Chevy has discovered why so many new Z06 engines are self destructing very early in their life. The machining for the oil filter mount leaves metal which finds its way to the crankshaft, with immediate damage. They say they have resolved that manufacturing problem, but still recommend changing oil at 500 miles.
If I had a Z06 I would forever have anxiety that sooner or later, my engine would blow. Sort of like the coolant pipe concern we have for our Mezgar motors.
Learned how to put up Crown Molding at my daughter's place in Charlotte yesterday. Using a penumatic nail gun is fun. Didn't even nail my hand to a stud, either. Her boss races GT3's and told her he would be interested in having another, like mine. Not selling.
All the best...
All the best...
