997 GT2/GT3 Forum 2005-2012
Why my brake pedal goes soft on the track
Old 08-18-2015, 12:32 PM
Jake951
Jake951's Avatar
Default Why my brake pedal goes soft on the track
A few months back I posted this thread, "Why does my brake pedal go soft on the track?" (https://rennlist.com/forums/997-gt2-...highlight=soft). I now know the answer but I'm not sure how to fix it. I'm hoping somebody in this forum can help.
To recap the original problem, the brake pedal would start to get "long" on the track. As the brakes got hot, it took more pedal travel to get braking as a track session progressed. A quick tap on the brakes before hard braking would temporarily restore the brakes to normal, so that became my braking routine on the track. On the street, the brakes never had the problem and letting the car sit overnight after a track day would restore the pedal back to normal.
After eliminating a lot of potential causes, including brake fluid, master cylinder, rotors, pads, brake lines, and everything having to do with hydraulics, my shop finally discovered that the cause is the brake piston seals pulling back the brake pistons so that a gap opens up between the pistons and the brake pads. It is not much, a fraction of a millimeter, but it is clearly visible by eye. A quick tap on the brake pedal closes up the gap for a moment before the seals pull the pistons back. We were able to replicate the problem on the bench with the brake calipers completely removed from the car. The piston seals were Brembo seals and the calipers are the OEM GT3 calipers.
My shop rebuilt the calipers with new StopTech seals instead of Brembo. Guess what? The problem still remained and was even worse than before. It was really bad now even on the street. A suggestion was made that the seals, being rubber, have mechanical "memory" which causes them to pull the pistons back into the calipers when the brake pedal is released. A trick that was suggested to fix it was to let the car sit for an extended period of time with a broomstick pushing down on the brake pedal to force the seals to form new "memory". This is what I did:
After 24 hours I took the car out on the street and the brake pedal was now dramatically better. The pedal was rock hard and better than ever. This seemed to confirm the theory about the seals.
Unfortunately the great street behavior with the new seals still did not carry over to the track. The brake pedal would go "long", just like before, and would recover overnight. I still had to do the quick brake tap routine on the track. I've tried the broomstick some more, for days at a time, but still have not improved the track behavior by much.
Now that I know it is the seals, I am at a loss as to what else I can do. My shop has rebuilt lots of calipers with new seals, including other track GT3's, and my car is the only one with this problem. I know of at least one other GT3 that has the same problem, so it is not an unknown issue.
I have now run out of ideas. Do any of you experts have any more insight into this problem and how to fix it?
Old 08-18-2015, 01:21 PM
audipwr1
audipwr1's Avatar
All calipers or just one?
Old 08-18-2015, 01:25 PM
Tacet-Conundrum
Tacet-Conundrum's Avatar
What pads are you using; Pagid(?) and what fluid in addition?
Old 08-18-2015, 02:21 PM
Spyerx
Spyerx's Avatar
Received 1,826 Likes on 1,111 Posts
Remove the outer seals. Cup cars don't run them. Interesting I seem to rcall the previous thread suggesting knock back bit this is the seal vs floating rotor causing. P
I've rebuilt a few calipers and a not and this issue. Makes me wonder of the inner seals are worn and getting pulled in too easy. The action on the outer seals is not strong.
Did they rebuild the inner and outer seals and inspect the Pistons and bores?
Old 08-18-2015, 04:50 PM
KA MOTORSPORT
Former Vendor
KA MOTORSPORT's Avatar
Soft or spongy pedal is always going to be some kind of hydraulic issue and caliper seals play a big part in the consistency and feel of brakes. This is different from knockback.
Seals need to be serviced every 5000 km or if there is any sign of leakage (that’s what we do on the cup car & race calipers). Have to use proper seal conditioning fluid and soak it in overnight too, otherwise sometimes the seals don’t work right. Street GT3 and 997 Cup have standard calipers with a standard piston seal and dust boot….burning the dust boot won’t do much harm but if the seals are worn, then performance will go down.
If there is any damage to the pistons, we replace them immediately.
From my experience, Brembo seals work best in Brembo calipers even though sometimes a pain to source. Other brand seals in most cases, makes it worse.
Otherwise, the only other time I have seen such symptoms is if master cylinders need service. Happens on the Cup cars but not so sure about the street GT3.
Old 08-18-2015, 04:52 PM
Jake951
Jake951's Avatar
All calipers, but not every piston on each caliper is doing it.
I've tried PFC08 and Hawk DT70 pads, and the results are the same. I've also tried Motul RBF660 and StopTech RTR660 as well as lower temperature fluids, all with no improvement.
Yes, all inner and outer seals were replaced and all new pistons were installed in the most recent rebuild. The ceramic heads on the old pistons were showing cracks and the old pistons also had some scoring on the sides.
I wonder if my brake calipers are bad. Is that possible?
Old 08-18-2015, 07:44 PM
KA MOTORSPORT
Former Vendor
Originally Posted by Jake951
All calipers, but not every piston on each caliper is doing it.I've tried PFC08 and Hawk DT70 pads, and the results are the same. I've also tried Motul RBF660 and StopTech RTR660 as well as lower temperature fluids, all with no improvement.Yes, all inner and outer seals were replaced and all new pistons were installed in the most recent rebuild. The ceramic heads on the old pistons were showing cracks and the old pistons also had some scoring on the sides.
A proper brake fluid like Castrol SRF or Brembo HTC64T will definitely help.
Who performed the servicing of the calipers and how much track mileage do you have on the calipers?
The Porsche OE red calipers have an inner piston seal and a dust boot. The dust boot and ceramic puck only protects the inner seal but has no real effect on pedal feel. If the pistons were scored, then the calipers should be inspected too for damaged bores.
Old 08-18-2015, 08:14 PM
Jake951
Jake951's Avatar
A local motorsport shop did the work. I have at least 60 track days on the calipers. They have been rebuilt twice with new seals and dust boots.
Also tried the Castrol fluid although not the Brembo.
The master cylinder was replaced and that did not help. Wouldn't a bad master cylinder also cause soft brakes on the street (which I don't have)?
What kind of seal conditioning fluid is recommended? I assume it's not just brake fluid.
Old 08-18-2015, 09:08 PM
KA MOTORSPORT
Former Vendor
No it's seal conditioning fluid from Brembo. Without putting the seals in it over night we have seen many failures.
Old 08-18-2015, 11:32 PM
Spyerx
Spyerx's Avatar
My guys soak the seals at least over night. Same deal. Need to condition them.
I think what ka is saying is the boots are not the issue. Something else weird.
Old 08-19-2015, 05:48 AM
mm450exc
mm450exc's Avatar
As you know John I got the same problem on my 2010 GT3.
Done the following:
Alcon with RS29 pads
ATEC brake lines
New Master Cylinder
New ABS Module (One circuit did not cycle)
SRF brake fluid
As per suggestions I will have brembo rebuild the calipers and add titanium shims.
Old 08-19-2015, 06:52 AM
Jake951
Jake951's Avatar
I also tried titanium shims. It did not help.
Old 08-19-2015, 07:25 AM
mm450exc
mm450exc's Avatar
We only have the problem when hot on track. When cold the brakes are rock solid! You reckon it's the seals? Replace with standard brembo seals or does brembo make anything better?
Old 08-19-2015, 07:34 AM
Jason @ Paragon Products
Jason @ Paragon Products's Avatar
Do you left foot brake?
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Old 08-19-2015, 08:10 AM
mm450exc
mm450exc's Avatar
No
Quick Reply: Why my brake pedal goes soft on the track
