997.2 summer refresh
After just over one year, 30,000 Kms and 15 trackdays, decided to have the motor dropped to have a look. There was nothing wrong with the car.
All the coolant lines got pinned and the Sharkworks pipes were installed. New spark plugs, new water pump, etc. Interestingly, the coolant lines seemed fine. No apparent sign of failure. Another data point to muck up the discussion.
New diff internals from Guard/GT was installed. My god what a difference. Been to the track once since the refresh and I could not get on the power early enough. Looking forward to some wet trackdays now so I can channel my inner Chris Harris.
Put in a new clutch and flywheel while at it. Decided to stay with the dual-mass. With all this talk of harmonics, I know enough that I don't know enough. So left well enough alone.
Strange feeling to spend all this money to replace things while technically nothing was broken.
Next will be the brakes. Changing from OEM and Pagid Yellow to Girodisc and PFC 08.
Finally, wanted to give a thank you to the guys at Scan Automotive. They have been great to me over the years and continue to deliver top-notch service.
Some pix for clicks. Pretty clean on the inside for a car that is driven rain or shine.
Planning to do the same pretty soon... Not looking forward for the expense.
Kind of on the fence with all that's been said for the Light Weight Flywheel as well. Seems like an unnecessary nuisance for marginal performance gain.
Question. Looking over the picture of the de-mounted motor, what is the cooler on top of the motor for? I believe the tall, vertical one at the front of the motor is for the transaxle, but what is the smaller, flat one with lots of plates for?
all the best.
all the best.
I've only driven 997.1 with a LWFW and it is really nice. The extra chatter/noise is no big deal. To me, the gains are mainly for city driving. The car just revs up better and is easier to heal-toe at city speed. But that gain did not offset the potential/theoretical engine problem so I stuck dual-mass. On the track I don't think I miss it, its fun enough and I have plenty of other places to improve on.
Interestingly, under braking the car never felt that unstable. It was nothing like the open diffs I had in my 996. More stable not but not horrific before either.
No doubt, it is expensive. But my diff was gone, so I decided to bite the bullet and get everything done at once. Also, the tracks that i go to are about 4 hours away and in another country, so a blown coolant line would be extra inconvenient. The dream is that the motor will not have to be dropped for another 100,000 Km.
The chatter is negligible as long as no cup shifter cables are installed. I've done a quick math and it adds up quickly if you want to add the LWFW on the .2's. The Clutch & FW approximately cost $3k, the damper is another $1k or so, if you get the updated actuators those run for about $4k. So you're looking at $8k before labor just for parts. That seems insane!
I'd rather get a nice set of coil overs instead of spending so much just on a freaking LWFW and have money to spare!
