Exhaust (?) rattle
I am experiencing a "rattling" that no one has been able to locate on my 2007 RS. Comes from the rear, hard to be sure which side, but I would guess the driver's side. Sounds like a clamp on the exhaust is loose, and only seems to be really loud when coldish. I have had it up on the rack and inspected by two dealers looking for something loose, but no luck. The noise started after I had my plugs changed, took it back to the dealer and he said a loose spark plug shield was the reason. The noise started up again shortly thereafter, and the next dealer couldn't find anything loose. I thought maybe the internals of the side muffler were coming loose, but if the cats are self-destructing, that needs to be addressed asap!! I was instructed to disconnect the rubber lines that actuate the exhaust flapper valves - they supposedly can rattle and doing this would isolate those two components. After doing this, no change...the rattle is still there. No codes, runs perfect, seems to abate some when warmed up. I have a Sharkwerks ECU & bypass rear exhaust section (checked for rattling) and complete RSS Tarmac kit...otherwise box-stock. Could it possibly be associated with the clutch pressure plate or fork? Thanks in advance for the advise.
I had a rattle in my car that the dealer couldn't find. It turned out to be a cracked center muffler. The crack was under the mounting clamp, so it was hard to find. It is pretty common in the .2 RS since they have a titanium muffler.
Is there something metal between the side mufflers and the bodywork that could be rattling around? When my wife and I gently thumped the rear valance side areas (both sides) and heard a slight, muffled rattle (going over bumps while driving obviously shakes it harder than we did with our thumping) that sounded like it could be the cause. Anyone who has pulled his RS mufflers has seen what it looks like in there. Any description and advise? Thanks greatly.
Texas RS, thanks for the info. Are the shields attached to the bodywork or the side mufflers? Are they metal that could rattle? Thanks again.
The rattle, even after numerous "thumb bends" to the heat shield, is still present. I do not want to go hog wild on this "thumb bend" technique that my tech told me to use to quiet the panel down. Does this panel attach to the muffler can or to the bodywork? Does it have a system to attach it to either the bodywork or the muffler can, or does it just stay there by magic? Any assistance would be greatly appreciated.
Unless it's a very high frequency rattle/vibration it's not the heat shield. They are light weight corrugated and pliable aluminum... They don't rattle. Maybe buzz, but even then it would be low intensity/volume. Try taking a video of the sound. My guess is it's the internals of the side muffler...
Slowandsteady, did it turn out to be a muffler issue? Broken internals? Was this a 997.1 GT3? Thanks to you, AEsco48, and Texas RS for your help. I will now try the rubber mallet technique. I don't understand why my technician is reluctant to put it up on the rack, pull the side muffler(s) - I have SW center section bypass - and find out what is going on. Does the rear bodywork (fascia?) have to be removed to get to the mufflers? How many hours are involved in a muffler removal? Thanks again.
Being that the .2RS had Ti muffler cans, they would be more complicated to cut open and repair as I intend to do with my .1RS (has conventional steel, although probably galvanized). Thanks so much for all the help.
check the muffler mount brackets that bolt to the motor. i had one crack/break and it made a bunch of noise. you'll probably have to pull the mufflers and then get under the car to inspect the brackets. if they flex at all, you've got a crack/break or broken weld. i think this condition is caused by running by-pass pipes with the brackets still bolted onto the motor (not removed) - the brackets would vibrate like crazy in that situation and probably start to fail over time.
