COTA Question - Tires & Brakes
#31
Watch the top supercup/tudor qualifiers in GT3s. There is a lot of misinformation at DEs about how to drive it.
#32
Pretty interesting how he goes behind the curbing at 2 and 8-9. I can't tell but did he go behind the orange bump at 19? Probably not as it would destroy the bottom of the car but it almost looks like he did.
#33
I've also seen COTA remove / include a yellow curb at the last turn before the pit straight (T20?), and there were other corners also but I can't remember exactly which ones. In any event, just because you see someone cut over the red/white curbs in a video doesn't mean you'll be able to do the same depending on how the curbs are configured.
#34
Paver - The orange hump at T19 apex is smaller and is a different shape. It has a more rectangular footprint, is narrow, follows the inside line and is not as tall. I know some E46 M3's that straddle it to really close on people coming into T20. I have not tried it, but it can be done.
Drew - T19 is the one before pit-in.
Right after the F1 race, there were some nasty gators in the astroturf at track out of T15 and T20. That astroturf sees lots of cars, but they kept me honest that weekend.
#35
You also have to be wary of other people's videos because COTA changes the configuration of the yellow curbs, i.e., the potentially suspension damaging curbs. I drove at least one event there where they removed the yellow curbs through T3-T5, so I drove right over the middle of the red/white mini-curbs, which made that section a lot straighter.
In particular, the line/cadence through 2-3, 5-6-7, 7-8-9, 13-14-15, 16-17-18 are key areas where time is hard to find if you think about the corners geometrically - without looking for the most grip or camber.
I still can't make 19 work the way I want, there is a ton of speed you can carry through there if you get it right.
#36
All the DE's I've run there the orange curb at the apex is pretty far in. You'd have to have about half your car over the red/white striping before you'd hit the orange curb. I use a decent bit of rumble strip through the esses and also at T19.
The best way I found to drive T19 is to make sure you're not too far over to the left side after T18, make sure you are set up way to the right of the track and then turn in early and dive for some rumble strip at T19 and then get back on the gas.
#37
We're just one day UPS ground shipping from COTA if you need Pagid pads delivered to the hotel or track.
Your Porsche Parts Superstore
![](http://www.paragon-products.com/v/vspfiles/assets/images/pagidrs2.jpg)
![](http://www.paragon-products.com/v/vspfiles/assets/images/Paragon web logo.gif)
![](http://www.paragon-products.com/v/vspfiles/assets/images/konilogobkbgsm.jpg)
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
#38
I liked this video of COTA the best since it shows data....(so a sub 2:30 lap is quick?)...
#42
As a newb to COTA running NT01/RA1s, I'll shoot for a sub 2:30 lap.
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
#43
#44
6.5 weeks to countdown.
#45
I'm be running fresh NT01s/RA1s so won't have the cheater tires. Which groups are you guys in? I'm in Yellow with 85Gold. I think Spyerx is in Red or Orange (forgot which one).
