I have a cover in the stock grey finish that you can have. I don't know that it will solve your problem though, it really depends on whats broken about it.
The cover is fine. It just wont stay closed...I believe its the latch located in the center (see pic)...just doesnt seem to be catching when you push it up.
If in SoCal take your E500 to Sammy at Point Auto Service in Santa Clarita. He worked on my E500 5 years ago and I think still maintains it for the new owner. http://pointautoservice.com
E500? ....this is an 07 .1 RS
Thanks for the suggestion, however I'm in central Florida.
Mine will close and stay closed except at the track when the car takes a good jar. then it'll pop open. Drives me nuts because I always feel compelled to shut it right away and bang! next lap it's right where it was again. Repeat for next 30 minutes.
Just embrace the situation and put your latte' in it. You may even drive faster without a latte' in your hand.
Oh wait, wrong forum..
Seriously though, use a little blue painters tape to ensure it stays closed. Easy peasy.
2 ~8mm? allen screws on either side, accessed from bottom when glove box open, remove those, pull out cup holders, put in a box. You can remove the whole unit and replace with the .2RS non-cup holder version too... plastic won't match tho in color. So far mine stays shut.
