Suspension mod : Dynamic Suspension Control
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
A few weeks ago, I inquired whether any GT3 owners had tried TPC's product called DSC or Dynamic Suspension Control. It replaces the OE PASM module.
See: https://rennlist.com/forums/997-gt2-...n-control.html
Well, I've installed it and it has completely transformed the vehicle's handling characteristics.
Before the car was jiggly and wiggly upon hitting any road imperfection. Now, the chassis just blasts through pot holes and over expansion joints with a solid thump. No longer do I feel the dreaded "po-go stick" after-bouncing that plagued the OE set-up.
While stiffening the compression/rebound rates would seem counter-intuitive, it is just what the handling needs. The ride is now so much more sure-footed and stable.
Installation is a snap. Just remove two plastic screws holding up a thick piece of foam lining located just beneath the glove-box; push back the edge of the carpet and un-seat the OEM black module held in place w/ a tensioned plastic strap in the middle. Remove the wiring connector. Install the replacement gold box in its place. Five minute job on the 997.2.
997.1 owners need to install a separate accelerometer.
There are 3 modes:
Mode 1 = PASM button stays lit. For street or wet/bumpy tracks;
Mode 2 = PASM button blinks 2x. For medium smooth tracks;
Mode 3 = PASM button blinks 3x. For ultra smooth tracks.
The light is not distracting (and will only blink in track modes).
I am very pleased w/ the results and think you will be too.
There are 3 modes:
Thanks for the update.
Also posted in the 997 forum...
Quick review of TPC Racing Dynamic Suspension Control or DSC for PASM equipped cars. For those of you who do not know TPC Racing has taken their years of suspension setup knowledge and put it into a software upgrade/control module box to replace the factory PASM box. Tom at TPC set me up, really nice guy and a wealth of knowledge.
This software/hardware is for the 997.1 and 997.2 cars with PASM. The .1 cars also need a 3 axis accelerometer wired in as the system relies on the accelerometer to dynamically adjust the dampening on each corner of the car. The 997.1 cars only have a 2 axis module from the factory (except the turbo and GT2). The .2 cars have a 3 axis system as part of the stock electronics.
This is really cool tech using stock PASM shocks and taking them to the level they are capable of through the DSC module. Couple the technology with TPC’s years of suspension tuning knowledge and you have a great package to take your car to the next level of handling without turning a single wrench.
This module replaces the stock module which is located in the passenger foot well, upper right side behind the carpet, a 5 minute install. The system then operates off of the PASM button that just has an on and off setting. The new module has three modes: This is not a static system as it adjusts each shock based on the loads the accelerometer and other metrics fed to the DSC box, TPC will have to chime in on the actual technology and specifics. It is also important to note that this system can be re-flashed with updated software from time to time.
DSC modes (from Tom at TPC):
Mode 1 = PASM button LED light lit solid. Softest peak stiffness of the three modes. Best for street, very bump tracks, wet track.
Mode 2 = PASM button LED light blinks twice. Peak stiffness stiffer than Mode 1 only in the higher load range. Best for medium to smooth tracks.
Mode 3 = PASM button LED light blinks 3x. Same as Mode 2 except the rear shocks will be stiffer during corner entry to transfer weight to the front. Good for reducing corner entry understeer if your car behaves as such.
My experience so far was last Sunday at a morning open lapping day at High Plains Raceway outside of Denver. This is a very technical track, off camber, blind and tightening radius corners, fast sweepers and slow hairpins. A good place to test.
My car did fairly well stock but did not feel stable especially during the heavy braking from 130 mph on the back straight into a 85 mph right hander, and through some flat out esses leading to the front straight, the car felt unsettled before, not any longer.
The DSC transforms the car, it is now much more stable under all conditions but especially noticeable during the heavy braking and during fast transitions (side to side). Overall the car is just more balanced, it is a great improvement. My lap times improved and became more consistent.
I drove primarily in mode 3 as this is a new track very smooth and fast, my car did push significantly before and does so far less now, interesting to note that mode 3 will help with understeer, I was unaware of the mode 3 programming at the time and it does make a difference.
I am very pleased, I need more time playing with the settings and getting some time on it, this weekend I have a DE with Porsche club I will have some more time to test it out. I will report back.
I would so love to plug one of these in and try it out for a session at a DE....I might be hooked though!
Premium Sponsor
Tel: 410-799-7223 (M-F 9am-5pm EST)
Email: info@tpcracing.com
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
Hi Tom,![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
My name is Juha Pussinen and am finnish but living in germany ,Munich.
Am new GT3 Porsche owner. year modell 2007.
Am following your nice writing in here this forum quite lot. Some treads are soo nice explaning your ideas and nice info about GT3 suspension and DCS and..things what is related of this.
Only things what I dont find anywhere is price range what this modification cost into my Porsche. Of course I can call you and ask but time difference and cost off calls maybe is suitasble if u can send me msg or info where I can find price info.
Thank you in advance.Juha P ,Munich
Sorry MikejGT3, the DSC is not on the TPC Racing website. DSC will have its own website. Please feel free to call or email us if you have any questions about this product.
Premium Sponsor
Thank you for your interest. I have sent you a PM(Private Message).
Best Regards,
Tom
