Low Temp Thermostat?
I have my motor out and know of talk of replacing thermostats with low temperature units to turn on sooner for faster cooling.
Please can someone tell me the exact part numbers i need and all the pars necessary?
Thanks!
Thanks!
I asked my shop about this and their response was exactly what serge suggested. Use Oem.
i did ask around and the shops were telling me anything low temp would not be an oem porsche part.
i am replacing my 3.8 motor and the advised to switch to a new t-stat.
thanks for the responses!
if anyone has a center radiator pls let me know.
Ok so this is or is not It a gt motor?
Yeah shop didn't even mention as an option. I'm sure it wouldn't hurt (didn't realize it was lower temp for cup,part) That said I've no cooling issues, and ran hard in 105 shade temp and never got oil above 245 or so.
road/oem stat is set for emissions and varied climates plus so HVAC works correctly for screen clearing etc in damp conditions etc.
Cup stat for racing/Hp. Your choice but it does work especially in hot climbs. Normally only ~7 degrees different.
About seven degrees different in water temp or resulting oil temp? My water temp rarely varies from 175 max while the oil temp increases above that. I am thinking the initial benefit is that the coolant t-stat opens sooner and then maintains a lower water temp, nominally 168F based on the 7 degrees you cited. As a result, does it also reduce oil temp by any appreciable amount? That would seem to be the ultimate objective. Thank you.
Thanks; good to know. I am new to the GT3, what is the average hot oil temp on track? From the analog gauge it seemed I saw about 210 with a max of about 230 in relatively mild ambient temps of about 75.
FYI I track my car in the UAE where ambient temps approach 40. Water temp is stuck at half, with oil going up to 120. Oil and water temps have never been a concern. The only time my car over heats is when I'm stuck in traffic in summer.
I might be wrong here but a thermostat should assist an engine is getting up to its desired operating temperature. How will a thermostat control the absolute maximum temps? I would have thought that's what radiators, airflow and aux fans would do.
I obviously didn't get enough sleep last night... You're right, over a modest range the t-stat only determines when the coolant is released to the radiators and allows the rest of the cooling system controls to work. The effectiveness of the coolant system seems impressive, as my water temp has not gone above the half gauge reading of 175 (yet) - even though the oil temps continue to rise.
Anyway, listen to the UAE guy as our 105 desert heat is a mild fall day for them :-)
My water temp per can bus will get up to 210 if I recall, but gauge shows 175. Oil meter is right on to can bus reading. My oil temps on normal temp track day are 210-225, water 190 or so. Really hot day at end of run was oil 235 water 210.
Forgot to add the bit about the water gauge not being accurate. You're correct, water temps do fluctuate on track, but not wide enough for the gauge to move. Quite a few GT3's are tracked regularly here, never heard of any overheating so cooling really not high up on the list of concerns.
Sorry I was posing in the gt section as this crowd is more familiar with the mods I have and intend to do. I have an 05 c2s
The oil temps are what I was concerned about, I was reaching 250
About to install a gt3 center rad as I have a gt3 front end - should help with cooling
