Seat Belt/Air Bag Fault Code Issue
Hey Guys, I recently installed fixed-back Sparco seats and Schroth 5-point harnesses and can't seem to find a way to code out the air bag warning... The factory seatbelt is still in the pillar panel tucked away, however there is no tensioner (thingy the buckle clicks into near the venter tunnel). I have the factory buckle tucked into the plane and out of the way. The fault codes I get that are persistent even after I coded out the seat belts, seat airbags and all other seat related ties are as follows: 8045 Driver's Belt Tensioner, incorrect coding 8046 Passenger's Belt Tensioner, incorrect coding I have read something about using resistors on specific pins of the factory tensioner plugs, but can't seem to find any info. Thoughts?
A 2.8 ohm resistor wired in place of the air bag will fool it into thinking the airbag is still in place. Try these links.
https://rennlist.com/forums/993-foru...stor-help.html
https://rennlist.com/forums/993-foru...-question.html
