Symptoms of a dying battery (or should I be more concerned)?
Trucker
I have been using CTEK for around 8 years on multiple cars...works great...I have 9-10 cars on charge.
Also...avoid Lead-Acid and go for a dry cell such as an AGM (advance glass mat)...lead acids can leak sometimes and you have expensive stuff under the battery tray of the 997...you don't want that kind of corrosion. Further, AGMs have more than enough CCA (cold cranking amps) and they can be fully deep cycled and then recharged to 100%SOC (state of charge) whereas the lead-acid don't like the recharge process....the plates get shocked and lose their life/performance...and oxidize...
IMHO...
IMHO...
Hey guys,
After a night of charging (on my other charger) the battery seems normal again. I started the car and drove it out into my driveway and all systems were working and no error codes shown. I shut off and started the car 5 separate times (cringe!) and it fired up every time with no hesitation.
So, at least I know that the error codes, etc. were from the weak battery. Now the only mystery is 'has my battery recovered or is it still compromised'? Only time will tell. Thanks for the good feedback.
You can take the battery to any auto parts store and they can load test it for you. They do this for free. Sounds like your charger failed and all is ok now though
IMHO...
IMHO...
Regarding my Lead Acid comment from earlier, I might have spoken too soon about that since I never looked at it to identify it 100%. It's a Porsche GT3 specific battery, and the non lithium-Ion (or is the stock one Lithium-Iron?) version that would come with the car. Anyway, so whatever the stock non LI battery is, that's what is in the car.
The Porsche part number of my battery is 999.611.070.00 and it is a Moll unit. What I meant was I was sure it wasn't Li-Ion but wasn't sure if there was a factory non lead-acid version too. That's why I wasn't sure it was lead acid but suspected it was.
The same battery is referenced in another thread here: https://rennlist.com/forums/997-gt2-...l-battery.html
Interestingly, although I have the complete service records of my car from new, I cannot for the life of me find where the second Li-Ion battery was replaced with a traditional battery. The Li-Ion battery was 'serviced' at 9 miles and again at 17,100 miles, but no mention of anything since then.
IIRC cars optioned from factory with the LION battery also came with a regular battery. It was probably swapped and sold at one point or it and died.
That Moll is a normal lead acid battery. I'm pretty sure porsche has not used AGM yet at least in 997.
If you need a new one just get an Interstate MTP48/H6.
