Making GT3 better for DD?
Ok, I probably will be flamed, but what the heck...
I was wondering if anyone's tried to make GT3 more daily friendly? Specially to reduce cabin noise. I know, I know... that's exactly going against anything GT3 stands for, but I am just being curious to see if there's a way to do that with adding a bit more sound proofing, and possibly rear seats (probably not insurable)?
Flame away!!!
Flame away!!!
Flame away!!!
Flame away!!!
dont ever replace your rubber bushings for anything else if you dont like additional cabin noise ... I put RSS LCAs on the back of my car ... sounds like I am on "wagon wheels" on some surfaces ... giddy up there!
The reason I am asking guys, is to see if I could swap my Carrera to GT3, and still use it daily/track.
The ride isn't actually that bad IMO, specially with PASM, but in a long stretch, the noise could be too much. I believe there's less sound dampening for obvious reasons, can those be added back?
Tire change would help and plan to use MPSS.
one would be tough...
MPSS will make it a bit less noisy ... not all lot though
Prior to having them do an alignment and corner balance I had Goldcrest raise the ride height 20mm to help preserve the new spoiler lip.
I just bought a set of Bridgestone Pole Position S-04's to replace the current worn Michelin PS2's but I haven't installed them yet. They are on sale at Tire Rack now and should work fine for my street-only usage. I had a set of these on my ex-993 and they were fairly quiet and were compliant on bumpy roads.
Even with the previous setup, I thought that the "ride" was fine considering the GT3's intended usage...these aren't Cadillacs!
I get where the OP is coming from, I think of my GT3 as a daily driver and intentionally chose the GT 3 over the RS because of the noise issue along with other drivability factors, since the car was going to be a road car.
In addition to what others have said, I was able to pick up a leather 997 headliner on ebay (in red, no less), I think the one I have is from Porsche Exclusive. Made a noticeable difference in decreasing cabin noise, maybe acting as both an insulator and sound absorber. I also like the cabin better.
For noise, I have a 993 4S with Dach X Pipe and FD Stage 2 muffler - noise is much, much more raw than the one from the GT 3.
Ich verstehe es nicht, but then again....that's likely my shortcoming. Never could understand why some choose Honda bikes.
