DIY: 997.2 GT3 spark plug changes and lesions learned
I looks like the difference between the two is the FGR5NQE04 has 4 ground electrodes whereas the Y5DDC has 2. My original plugs also had 2 electrodes, I'm wondering if 4 electrodes makes a difference. Anyone know?
it is EXACTLY the same as .2 on a .1, even the same plugs... easy 40 min job including jacking up - allow an hour if you are pedantic and its your first time... just do it and you won't have to refer to this guide!!!
A number of the Rennlisters advise removing the mufflers on the 997.1 and 997.2's to access the removal of the spark plugs. I was able to complete the job without removing the mufflers on my 2008 Carrera S. I asked a trusted Service Advisor if the Porsche mechanics at the dealership removed the mufflers on the 997.2 to change plugs. He said that they didn't. I think I will give it a try with the mufflers in place.
By the way, 6 Bosch spark plugs for my 997.2 were less than $60.00 delivered and a Contitech serpentine belt was just over $20.00 delivered on eBay. Both Bosch and Contitech are OEM's to Porsche. Same part, different box.
Part #'s: Bosch FGR5NQE04
Contiitech: 6DPK1853 (I always carry a spare).
Contitech might be oem supplier but their belt quality in a Porsche box is different than the one you will find in their own box. I would not buy a Contitech belt that is not in a Porsche box.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/213d0623_7374_4f92_8938_da3d62a5add6_407bd11f902775c201beb251fd2af90699705e65.jpeg)
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/211685d3_4a74_4286_80e1_fbc17a394e5f_6a4e5086b4c7f3c29b177527387ad2c5dd80e806.jpeg)
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/5596074d_23dc_40d0_b6a8_199c8a083262_ae70cc7b11eab681e974dfb0bac48674ac024e61.jpeg)
Just adding some pics, weather was nice today so I jacked up the car and put new plugs in👍
I used the magnetic socket from Gear wrench,-it’s really a must if you ask me,-got it at Advance parts $10.99
an extra extension made it perfect, and the torx on a ratchet also worked well. To take the shield off I just used an 8mm socket,no issues
Nice pics, thxs... I have this job waiting for me once it warms up a bit here.
