This look right?
I can't intelligently comment on the measurements but, where was this done?
I can't believe that they spelled caster wrong; kinda makes 'em look very amateurish.
Front toe should be zero-ish or slightly negative ("toe out") and the use of castor and kpi suggest this was a generic reading off some antiquated or poorly set up equipment. Just check the owner's manual for the "race circuit" spec to get reasonably good alignment and ride height, then get the cross weights within a few percent and the car will come alive.
The receipt listing suspension mods mention -3.0 camber but the car was aligned for the street so I could drive it cross country. The alignment I have now is what was suggested to me by my local shop. Having said that at limerock thurs I didn't have much grip in the front. I am new to a 911 on the track, I was practicing trailbraking into the corners all day so I don't think that had so much to do with it. Also playe with different tire pressure without.
