997 GT2/GT3 Forum 2005-2012
gt3 rs 4.0 akrapovic evolution race line
Old 07-01-2013, 09:09 AM
mariognutti
mariognutti's Avatar
Default gt3 rs 4.0 akrapovic evolution race line
good morning,
last week I installed an evolution race line exhaust system on my porsche gt3 rs 4.0
after that I did a dyno test and the result was 4hp power increase only compared to a one day before dyno test with the original exhaust system.
why a so poore improvement?
is there something wrong? I haven't remapped the ECU yet... do you know if the akrapovic hp improvement declared is with a new ECU setup?
thanks a lot for your help!
mario
Old 07-01-2013, 10:22 AM
M3EvoBR
M3EvoBR's Avatar
Hello Mario,
By Evo race line, did you also installed the headers ?
Please also take in consideration that by not testing same day, minimal temperature difference could easily impact the result, which had a delta of about 1% per your statement. This could easily vary.
Akrapovic doesn't use long tube headers, and also their exhaust systems doesn't have any improvement in diameter over stock.
I did several tests with different exhausts, and also different designs and diameters. You most likely had some mid range improvement in power and slightly torque.
Also the 4.0 uses a smaller count cat cell unit which improves flow over a 3.8 car leaving less room for improvement.
Here is a same day, same dyno test on a 4.0 RS ONLY with rear muffler replacement and side muffler delete. No ECU re-mapping.
Old 07-01-2013, 10:37 AM
Nizer
Nizer's Avatar
Received 1,885 Likes on 972 Posts
16hp w/o a header change? Nice.
Old 07-01-2013, 10:44 AM
mariognutti
hello M3evoBR,
thank you for your answer.
yes, I installed also the headers.
I'd like to know if it's normal and if akrapovic specs are with ECU remapping included.
this evening I'll post the graph with new ECU.... we'll see...
please consider that my 4.0 output in original configuration is 501 hp, with the complete akrapovic evolution race is 506 hp (same dyno with controlled atmosphere).
Old 07-01-2013, 10:50 AM
M3EvoBR
M3EvoBR's Avatar
It's quite normal, and no the Akrapovic specs are without ECU tune.
Please post your dyno sheet. Also please note that you should make at least 3 runs in each configuration, to give a little bit of time for the ECU to adapt.
The graph above shows the best runs of both set up (stock and M&M exhaust) which were about 3 runs each give or take.
What kind of dyno did you use ?
Regards,
Eddie.
Old 07-01-2013, 10:51 AM
M3EvoBR
M3EvoBR's Avatar
Tks. Yes this is Trakcar same day test we did a few months ago.
There are some decent gains once you install a less restrictive set up.
Old 07-01-2013, 11:04 AM
mariognutti
this is the dyno:
http://www.facebook.com/pages/edit/?...e/279042017853
basically I have 10hp lack by akrapovic specs! might be because it's a 4.0 and its stock exhaust system is more powerfull than the 3.8 one?
this evening I'll post dyno sheet
Old 07-01-2013, 01:43 PM
M3EvoBR
M3EvoBR's Avatar
Mario,
The exhaust is the same as the 3.8 RS, although the headers have different catalyst converter cell counts, being less restrictive.
Those cars really benefit from a less restrictive system as you could see on the dyno sheet above.
Old 07-01-2013, 07:09 PM
mariognutti
this is my last dyno sheet:
test 8 is the original car condition (501 hp)
test 22 is with complete akrapovic evolution race + remapped ECU. now the output is hp 527 (+ 26 hp).
what do you think about that?
thanks a lot for your comments...
Old 07-01-2013, 07:22 PM
M3EvoBR
M3EvoBR's Avatar
Any sheet from the exhaust change alone ?
Old 07-01-2013, 07:24 PM
M3EvoBR
M3EvoBR's Avatar
Gains are solid, all across the board, but if you didn't have any gains with the exhaust alone, you're leaving something on the table, specially after replacing headers and exhaust.
Old 07-01-2013, 08:00 PM
mariognutti
M3EvoBR,
you are right.... tomorrow I'll post a sheet with original condition vs exhaust change alone...
have you seen the big dip between 2000 and 3000 rpm?
Old 07-01-2013, 08:05 PM
M3EvoBR
M3EvoBR's Avatar
Ok, sounds good. Don't even consider anything below 3500-4000 RPM in those cars, as you will never drive them in this range. Specially the RS cars with short gearing, you're always 4000RPM or higher.
Look past 3500 RPM how much gain in torque and power you have.
On a side joke - This is not a Diesel VW...
Old 07-02-2013, 09:54 AM
mdrums
mdrums's Avatar
M3EvoBR, didn't you find that the M&M system to have the best gain in power all over?
Old 07-02-2013, 02:44 PM
mariognutti
this is the original condition vs exhaust change alone:
File Type: pdf
File Type: pdf
File Type: pdf
Quick Reply: gt3 rs 4.0 akrapovic evolution race line
