I need new Rear Tow Arms - Best Place/Deal?
My current adjustable rear toe steering arms are falling apart after just 1.5 years of ownership....I need new rear tow arms that can also adjust for my lowered car. I think thats called bump steer?
Where is the best place and deal on the RSS rear tow arms?
There was another thread on rss vs other brands. They all looked same except one company had a different locking nut on the adjustable threaded area so it was very robust...
Mdrum= please take a pic of your current one. How did it go bad or worn? The Monoball?
here are the only ones on the market that "look" different
http://www.championmotorsport.com/pr...cms-tstr-1.htm
I have RSS from RSS directly and their customer service has been great AND no issues with the parts at all.
I'd get the Tarret but there are twice the cost of RSS and look about the same. The RSS Rear Toe Link w/ Bump Steer adjustment is 1/2 of the Tarett version. Tarret has 2 version 1 with Bump Steer adjustment for cars that are lowered and 1 version that does not adjust for lowered car. My car is on Bilsteins and is lowered some and I take it I need the Bump Steer version.
http://www.grainger.com/Grainger/ant...ecatalog/N-9iq
Introduce your mechanic to anti-seize and you won't have this problem in the future.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Peter
Peter
toe steer is needed only if you lowered all the way down comparable to the level of cup car. I doubt you got that low as it would also require alterations for arms in front.
Get arms with ERP ends, they should last longer. ERP I got are slightly costlier than ones tarett sells but tarett also has ERP rod ends on most of its stuff. Check with direct distributors who deal with ERP. Cheap stuff is cheap as it falls apart faster and suspension arms are the last place where you would want to go cheap.
If I don't need bump steer for these are then the standard Tarret rear tow links are about the same price as the RSS.
I'm not looking for cheap rear tow arms I'm looking for a good price and place to buy from since especially RSS sells to a lot of various dealers in this stuff.
Here are the Tarret arms that do not adjust for a lowered car....to compare with the RSS arms above
ERP version which can adjust for lowered cars....very very expensive piece from what I can tell at around $700 a rod complete! Geesh!
my gut feeling from your car pictures is that you have at least an inch or so of a gap between top of the tire and your fender edge so that makes me to presume you are close enough to 'stock' ride height and not low enough to require bump steer arms.
not only that, if you have non-gt3 uprights, like I do, a geometry of our suspension is not optimal to be set for extreme low ride settings, I know some people still do it on 997 based race cars and 996 spec but I was told several times to avoid it or replace uprights and put all required extensions on front arms to maintain them in a relatively horizontal position as when you drop car down you can look in front how those arms in front change their geometry and move away from horizontal setting.
plus, an extreme low ride height on race cars is usually accompanied with cup car grade springs so it severely limits amount of travel for all arms - on a stock car with stock springs you may/will run out of movement easily enough and it will be not good at all.
Local to you is long time RL'er and sponsor, viperbob1 (Vortex Auto) who has put almost every conceivable suspension combination under every type of 911, road and race, so he'll have some preferences.
