Clutch pedal sticks on up movement
#31
GT3 player par excellence
Hi there - I think we just chatted and sure we'd be glad to take a look at it for you.
I can't speak for everyone but the reason we don't work on weekends is we're actually a small shop and if we did, we'd never get time off to drive cars
Luckily no divorces yet either ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
u actually have an life outside of Porsche?
tats just NOT right
I'm calling Alex, he needs to work u harder
Emily (ooh la la) Alex and james, I understand works 24/7
#32
mispost
#33
found my sticking clutch was OEM floor mat- it had moved out of align. Made pedal stick down when lift off the pedal and also made a step when pushing down especial when starting and the pedal has to be fully down to engage the starter.
Has happened twice now, quick fix is to rip out the mat and throw it into the passenger side and then refit later correctly.
I would never guess the carpet could do it as it feels very mechanical i.e something solid or metal!!
#34
Did you get this fixed?
#35
996 version of under pedal?
http://www.design911.co.uk/fu/pt376_...mission-Parts/
Mine is doing it when cold occasionally then works ok after pulling it up with foot a couple of times. Makes a mechanical sound when pulling back up.
