PCCB to steel conversion on 3-4 cars
yes, yes, yes. caliper studs are a must. before I learned my lesson I had two bolts mess up - at the track, day over. Twice. Idiot. Both cars are now studs.
Going back to the topic, I'm cureently using oem 2 piece rotors...but I rather save the oem parts for sale of the car (to get into an RS) I and use PFC rotors to abuse =)
Pads are amazing. Period. Try it then you will fall in love with it. Price vs performance... Nothing beats it.
Sooner or later those bolts will bend or break. Happened to me. Day over.
Sooner or later you will not set the bolt in correctly and strip the housing. Happened to me. Day over.
Another thing you need - those clips that hold the pucks in place. Rubber wears out and pucks fall out - total PITA trying to change pads when that happens. Eddie supplied me with clips that hold all my pucks in place, easy pad changes at the track (or shop too).
GT3 DE Cup brake kit:
PFC steel front rotors
Turbo rear steel rotors
PFC 08 pads
Stud kit (with a few extra nuts)
puck clips (order about 10 more than you need, helpful to give to a friend in need at the track)
one full set of pucks (these break sometimes at the track)
PFC 08 pads
Hey guys,
With regards to the rear turbo CL rotors for a 997.2 gt3, does anyone have the part numbers? Are they same in terms of thickness, drill pattern, longevity and look etc...
Too expensive to ship from the US so going to buy a jar of vaseline and visit the local dealer...
Thanx in advance
Thanx in advance
Hey guys,
Thanx in advance
Thanx in advance
