Aftermarket exhaust for my 4.0 RS???
#31
It was back to back runs. The motor is stock, other than no A/C and RSR Crankcase breather. Headers are stock 7GT3RS ones from my RS (its has the headers from the 4.0). It's just made more power when it went on the dyno. More importantly, it weighed 29lbs vs the stock 99lbs stock 6GT3 exhaust.
Enjoy
#34
Purely sound observations from CHIN Road Atlanta a few weeks back:
Sharky/RSS bypass - Sounds like the videos, not too loud.
GMG bypass - Like the above but more aggressive; snarls at high RPM; I really like the sound; plus, it has some race provenance
GMG bypass + headers, cats - Amazing. Purer, clearer tone than just the bypass. You could hear every minute variation in throttle position through the esses, and Grady's downshifts were absolutely savage coming into 6. I could also hear his car clearly as he went into 10A, and I was standing along the fence by the marshall stand on driver's right as you come into the trough in the esses. Best sounding GT3 I've ever heard (bar the race cars). Awesome setup, but not cheap! (Headers w/ cats, bypass, chip to take advantage, shipping, installation, tax, etc. - probably over $8,000).
#37
I have one on my 4.0. The sound is fantastic at all RPMs. I think it sounds best of all the center delete pipes I've heard. The quality is very high. No drone. Two issues for me: Just over AMP's 98DB limit and, I'm told by Topspeed Motorsports, that it is costing 10-14HP. This is based on their "experience" and a comparison to Seth's 4.0 dyno run and mine. Seth's was stock, Mine was done after the GMG was installed. Allan
#40
Eddie, Can your MM center muffler with side deletes be made to come in below 98DP without sacrificing it's benefits. I know Jenk's car with the side deletes, he is using, is just above AMP's limit, which they strictly enforce. Allan
#41
as a street driver you should keep the sport button feature thus center muffler delete is the way to go.
Sharkwerks has awesome custom service. If you have any issues they send you another right away. Gotta like that.
Sharkwerks also allows you to use your stock tips! Or, as i mentioned earlier, use their larger tips which i love!
#43
Jenk's car has just side muffler delete, with steel OEM center. The sound of the M&M is a lot deeper.
Do you know what distance is it measured ?
I can do a few different things to bring the sound down a little, but changing diameter of the muffler will also change gains.
At this point the main thing is to measure Peter's and than maybe try to work on baffled tips and see how do they work in case the sound needs to be reduced.
That's why I like to work with them, they're looking to help with custom applications
#44
All center deletes are more less the same.... all depends on their design/back pressure which makes one a little different then the other...
they all have pros and cons.
Sharky has great customer service and Alex is a great guy.
The GMG center bypass has better craftsmanship if you ask me, also like the design of the pipes.
