997 GT2/GT3 Forum 2005-2012
Put a Braille Lithium Battery in Yesterday/ Rep Offered RL's a Deal
Old 06-02-2013, 04:24 PM
  #46
m5trol
m5trol's Avatar
Can these batteries be charged/maintained with the standard tequipment trickle charger maintainer? It says to only use it on lead acid batteries, should I avoid it?
The trickle charger that came with the braille battery seems to run a little hot for me to leave in an arizona garage connected to power unattended.
Old 06-03-2013, 06:16 PM
  #47
deputydog95
deputydog95's Avatar
I leave mine unattended in a hot florida garage. Wouldn't worry about it. They suggest using their tender as it's designed for a lithium battery. Something about not going into a de-sulphering mode or something like that. Don't remember specifics. The braille tender wasn't expensive so I consider it cheap insurance for a relatively expensive battery.
Old 06-03-2013, 06:20 PM
  #48
M3EvoBR
M3EvoBR's Avatar
Let me know if you need a Braille tender, I have a few in stock.
tks.
Old 06-04-2013, 12:55 AM
  #49
m5trol
m5trol's Avatar
Well, the wires on the tender are too short to get to the battery without the tender being out of the trunk. I am just afraid of leaving it inside the car trunk.
Old 06-04-2013, 08:48 AM
  #50
deputydog95
I leave my trunk open and rest the tender on the shelf next to the battery. Works find.
Agreed on it being short and I've brought that to Braille's attention. However, doing what I'm doing works just peachy.
Old 06-09-2013, 12:15 AM
  #51
usctrojanGT3
usctrojanGT3's Avatar
Received 4,004 Likes on 2,282 Posts
Andrew, are they still running the special ($75k and free charger)?
Old 06-09-2013, 10:35 AM
  #52
deputydog95
Not sure... That was a while back. I can ask though.
Old 06-09-2013, 10:56 AM
  #53
deputydog95
PM me with your name and email address. I'll see what I can do.
Old 06-09-2013, 03:58 PM
  #54
usctrojanGT3
Sent you a PM...thanks.
Old 09-23-2014, 04:53 PM
  #55
Mvez
Mvez's Avatar
Just put my order in. I called up Braille, and Gary still honored the same original RL deal from this thread, $75 discount and a free charger. Pretty cool.
35lb weight loss, and a bit less hp loss from drag on the alternator will be appreciated. BOP adjustment for DE Cup....lol.
Thanks for the legwork DD95.
Old 09-23-2014, 07:51 PM
  #56
usctrojanGT3
I've had the battery in the non-RS and my RS and it works great. My car only gets driven on weekends so it sits for 4-5 days and it fires right up (cranks better than the OEM battery). When the car was at the dealer for the PS line replacement for 2-weeks, I dropped off the trickle charger with them just to be safe. Great battery!
Old 09-23-2014, 09:31 PM
  #57
cetro
cetro's Avatar
Can you still use battery tender with this battery?
Old 09-23-2014, 10:27 PM
  #58
Spyerx
Spyerx's Avatar
Received 1,793 Likes on 1,091 Posts
The deal they have they have for rennlist members includes a tender for the lion battery. CTEK also has one for lion that looks identical to the normal one but has charging curves for lion.
For convenience, I wired a ctek connector onto the braille charger since I wired a jack under the hood for my tender.
Old 09-25-2014, 09:38 AM
  #59
deputydog95
I've been absent for a while... Sold the GT3 and bought a 914-6 race car. It's cheap to the run the GT3 in comparison
Anyway, still using the battery. We moved it into the 914 and still going strong.
This is the nice thing about this battery. Even though it's expensive, unless you have a size limitation on your next car, you can continue to use the battery over and over.
I don't remember why as it's been a while since I researched it, but you should you really use an appropriate charger on these batteries as the lithium batteries have a preference as to how they like to be trickle charged.
Old 09-25-2014, 10:29 AM
  #60
Brh0nson
7th Gear
Brh0nson's Avatar
You can't use my boost box when ur car is dead Sunday am
Quick Reply: Put a Braille Lithium Battery in Yesterday/ Rep Offered RL's a Deal
