Centerlock Hub Failure Buttonwillow 5/25/12
#61
Very good analysis John (post #55).
Additionally, whether the car is operated on the street or track should not matter.
What does matter is that the car be operated within its design envelope. If the motor is not over-revved, if impact forces are not experienced, if the car is not adversely modified, what does it matter whether the tarmac underneath is part of the road or off-road network? The car certainly doesn't know.
#62
Ditto on Post#55 - well said John!!!
Human error on a long/complex procedure such as the CL R&R, is a very easy thing to happen. I believe that the procedure much too complex for the general public....and this, I think, is the point that Porsche (as thorough as they are) completely underestimated.
Doug N.
Doug N.
#63
Doug N.
Doug N.
The CL system itself has proven to be perfectly capable of doing what it was designed to do- hold the wheel to the hub. It is only after the wheel is removed/replaced that problems arise due to improper procedures being followed by some people. Compounded by Porsche making available a document to their dealers on what warning signs, caused by improper torque, to look for and not vigorously promoting the same bulletin far and wide outside the dealer network.
An education campaign from the very beginning would have gone a long way to forestalling the current issue.
PS- there are some things going on in the background and at some point in the next few days I/we am going to get a post up of warning signs to look for on the CL system.
#64
GT3 player par excellence
Doug N.
Doug N.
I concur with doug.
the design may or may not be flawed.
but if it causes ANY confusion, then it's bad news.
it needs to b fool proof.
#65
I know of one five-lug failure? Any system can fail if improperly serviced.
http://www.youtube.com/watch?v=jv4m41viy4I
systems should b simple and easy to use
I think we all agree five lugs are simpler than CL.
that's not to say five lugs are accident free.
there are precise ppl like izzon and savvy
there are common sense ppl like me
then there r suicidal crazies like the rx7 driver
some ppl can be helped others cannot
if one sees a tooth brush and insist on sticking it into his rear end to cln it.... well
#68
izzone and I had a chat on this.
All 4.0 have CL, CL fail......all 4.0 are now worth half
I'll do a 5 lug conversion on Giesha, you trade me your 4.0 for even money
you are safe, I beat Reter
#69
#70
I really like the way PCNA positions the GT3RS. Check out their website and the video - it's all at a track.
http://www.porsche.com/usa/models/911/911-gt3rs/
Porsche advertise the GT3RS as a track car - but no mention of lack of warranty when taken to the track.
#71
#72
This seems like a marketing problem for Porsche if someone dies as a result of a failure. How many times in the past has auto manufactures been sued successfully due to the manufacturer trying to save a few dollars and in the end costing them a lot more. I think CL's were a marketing idea to set apart our cars from the rest. Lets face it, they may look great but we own the cars because we like to drive them. It seems this failure was pretty well documented to leave some real questions in my mind to how durable this system is. If later on we find Porsche has known about this for awhile, then they risk not only money, but more importantly reputation which in my mind is irreparable.
#74
As an aside, I called my track insurer (Lockton) today. When I described a hypothetical event similar to this one, they said that they would have covered everything but the cost of the mechanical failure itself. All resulting damage would have been covered. Somewhat comforting. My car is off to my shop next week for usual post track maintenance and a full hub and wheel inspection. It will be added to the post track routine from now on.
#75
Now, I understand that they are not race cars. And if you enter your GT3 in a race that pays you money for your result the car would not be covered. However as stated above, if you drive the car within it's proper operating "design envelope" then how can they walk away from that. With ALL the computer stuff that they have on these cars Porsche can tell if the car has been driven outside of that envelope. If Porsche is going to keep on advertising a GT3 as the "ultimate track day weapon" as I have seen on Porsche videos, then back up the car, other wise say that the car is fast but no better designed then a Mustang and stay off a track.
I have always thought that spending all this money on a car like this meant something. That THIS car was different, better, durable. But now? I wonder.
