My GT2 build over the last year
#76
Nick The first who mentioned about the SC/TC issue in high hp cars was Toby RS tuning found out that 730hp is the limit for stock DME to work perfectly with all the other feutures of the car... Then the issue was brought up on 6speed and was not taken seriously by the Big HP Tuners out there..
We must be making a lot of HP, even on the base maps!
FYI, 730hp is not the limit, and since it's a torque limiting device- we should not use HP as a measurement, but ftlbs or Nm. I would venture to say (complete guess) 500ftlbs of torque at the wheels will trigger the SC, because I didn't see this issue with the stock block build until maximum boost maps were used. 730hp may be the limit for Toby though, since his car makes significantly less power overall than mine, which bumps OVER 800HP at the wheels on the big boy maps running C16 cut 10% with 93 octane street gas.
#77
Bringing this back from the dead... I finally have the spring info taken off the actual Ohlins springs in question. I'll cross post this to 997gt3north's "Tender Springs / bumpy tracks (Sebring) / suspension upgrades etc..." thread for future reference.
rear 05173-07/7/80 helper spring
rear 01096-93/230 L2110 main spring
front 05173-12/7.5/60 helper spring
front 25039-12/120/75 L2010 main spring
#81
This place and 6speed are owned by the same company. No reason to double dip, they are also at teamspeed but I don't post there either. In any case they are only a phone call or email away if you need any info on their products.
#85
#86
Only got to go through this thread now.. Nick your project is amazing!! Car looks stunning too!! I had a chance to drive a stock 997 gt2 a few years ago and that was already unbelievably fast... I can't imagine how this would feel!
#88
Thank you for the compliments. Much appreciated! The car is quite a beast.
#89
#90
