Flat tires?
I have a 2005 S that is new to me. Woke up to my first flat this morning of course it was only then did i realize that this car does not have a spare tire. Nor does it even have a jack in the tool kit, only a sealant and cigarette slot compressor. Other then a tow, what's the protocol most of you have been using when encountering a flat? I'd rather not fill my expensive tire with a bunch of gunk if it's repairable. Are there kits that anyone might suggest and/or spares that one can haul with these cars so I'm not stranded again next time?
Car is still sitting on it's flat. Fortunately I can see the nail and will try to extract it this time and put a plug in the tire so I can get it to a service shop and have it properly patched.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Get a floor jack, jack up the car, pull the wheel and take it over in another car to get it repaired/replaced. Don't use the fix a flat unless it is an emergency as it ruins your tire pressure sensors and they are expensive to replace. I did have a flat (puncture) on my GT3 and used Porsche customer care to have it flat bed towed to the dealer to have the tire replaced.
I drove my 997 TT from NY to CA, and was not about to get stuck in the middle of nowhere without a way to fix a flat. I carry a jack with me at all times, fits nicely in the front boot. I also carry a motorcycle tire plug kit, and hand-operated bicycle pump. Unless the tire is ripped, I should be OK. A flat from a nail is definitely repairable with this setup out on the road.
Thanks pal...If i wanted to consult my manual I would have done so and not posted here. Experience supersedes anything you'll find in manual...
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
...I guess this wouldn't be a proper message board without a "consult your manual nerd."
There are 4 jack pads under the car, 2 on each side inside the wheelbase near the wheels. They are easy to see and perfectly sized for a small aluminum race jack. Use the one near the rear wheels when you want to jack up a whole side.
Should you elect to follow the topics posted here, you will realize that almost all are very technical, well researched,and done with a great deal of care, you will also get a great deal of information from a great group of GT drivers that I am proudly one of...No nerds guaranteed.
I was only pointing the manual as your best reference for your Carrera which has its own forum.
