RS.2 Rear Window Blow Out!
Buy a standard 997 rear glass window. The weight savings on this rear window (plexi vs. glass) is insignificant, a lighter battery saves way more weight, and you will have clear visibility to the rear end.
I don't like my fiat Lexan window, visibility is horrible.
Well that is poor form on Porsche's part... Bet it doesn't say in the manual that you must keep your windows wound up when "accelerating hard" because the ****ty rear windscreen may blow out!!! Are these guys suppose to mind read and take precautionary action? If it isn't up to the task, they shouldn't fit it and they should look to save the measely 3kg somewhere else!
Interesting to note that both occurrences in the thread took place in the GCC.
Could this be linked to GCC specs? (which are very close to european specs)
or to the GCC weather eventually weakening the rubber/glue?
Are you guys storing your cars in a dehumidified garage?
Porsche should replace in such cases
How fast were you going?
Stupid quesion, but why did you have the window open - does the car not have a/c?
I had plexi windows in my GT2 and never had an issue even 200mph+, but i never opened windows in any car I owned at higher speeds.
And yes i am lucky to be alive after numerous trackdays home and blasting through the autobahn last year , glad it didnt blew the roof or coolant hose back then..
But that does not mean that if you open a window at 120kmh the window will blow out...
FYI it blew out at aorund 120 kmh which is within the speed limit, Porsche's engineering fault, Not my fault my freind , many people track their cars here with windows open.
And yes i am lucky to be alive after numerous trackdays home and blasting through the autobahn last year , glad it didnt blew the roof back then..
For me its a serious issues as it could have caused a serious accident. If I was not meant to drive the car with windows open, Porsche should have told me so in the manual and given me a car where the windows could not be opened!!
I took to car to the service centre in Dubai today, and they were extremely helpful. They took the car off me immediately, have taken photos and will send to Germany. Rear window on order.
For the record, my rear screen has always "popped" whenever I have closed the door - which I explained to the dealer and on this forum before, where I have been told it's normal. We went and checked another RS and the rear screen was solid, never popped when opening/closing the doors and could not press the screen down from the outside. Like 911Slow said, the seals go, so maybe this is what happened. Whatever the case, I hope its looked into by the motherland.
1 Post
Gee, C, this is something else! From your last post, I think what happened is the stress cycles created a crack line in the window and it eventually failed along this line, popping out as you were driving away. Must have made on hell of a noise!
Hope Nabooda takes care of it under warranty.
I wonder why they didn't add some type of venting to allow air to pass through when the windows are open.
Received 1,767 Likes
Heat will likely be a major factor! Not too many other places in the world that have such high temps constantly like their region...
