School me on spark plugs please
07 RS
Any reason to consider a spark plug other than the oem suggested Bosch?
Thoughts, experiences, etc
I know nothing and I did a search
GT3 player par excellence
What is the average cost to replace plugs on say a .2 GT3?
GT3 spark plug DIY
I'm going to be doing mine soon. I have 20k miles on the odometer and the car is 5 years old. I believe the manual suggests 24k miles or 4 years. Here's a DIY for the 996 - should be very similar.
http://www.euroaddiction.net/forum/g...placement.html
my tech says he prefers the high grade NGK plugs
I thought I would check here... I am not sure there is a really a "performance" advantage or anything but I keep hearing the phrase "run cooler than the stock plug"
Charles thinks NGK
Cheyne originally suggested a plug from earlier turbo (runs cooler)
I am thinking the oem is a known entity at this point
he is all over the map... hence me starting this thread
Charles thinks NGK
Charles thinks NGK
That's the plan now
Cheyne and I were chatting about possible answers for Nigel's engine failure and plugs were a suspect
So I thought I would post here to see if there was an alternative to oem that offered some benefit
Given the lack of responses I agree with your sentiment
