Just did my first brake change. Are you kidding in the rear caliper design?!?!?!?
So I just got done with my first brake job. 99% of the brake work I have done is on mine (and friends) 6GT3s, Turbos and Carreras. Piece of cake on those cars.
However...........
The rear calipers on the 997 is absolutely the worst design. Is there a RATIONAL reason why they changed the design to make it where you need to remove the caliper to do a brake pad swap? I can see marginally stronger calipers with the two connecting pieces on top of the caliper but really, was lack of strength an issue???
And as far as these cars being designed for quick changes in the pits, this makes no sense and pretty much relegates all teams to QD brake lines and swapping entire assemblies instead of pads.
Rant over.....
However...........
Rant over.....
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
This is seriously making me rethink my brake changes as it was a serious PITA. My shop partner (my 4 year old) was saying....."Daddy, why is this taking so long?" ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I told him that PAG wasn't thinking clearly when they designed the new 997 caliper. He asked if he could go back inside the house and watch Cars2
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Still plays with cars.
Dell, I share your pain. Stupid design compared to the earlier models. I have been told that with the improved bias (the 996 had way too much front bias) PAG decided they needed a more rigid caliper. So there went the bolt and cursed flat spring which allowed us to change pads without removing the caliper. Note, the bolts holding the calipers, front and rear are "one time use" stretch bolts. Just to add to the fun. That along with the stupid centerlock wheels makes changing pads an enduro. #$@!
Best,
Best,
However...........
Rant over.....![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
However...........
Rant over.....
Replace the bolts with studs, and it will make the job a lot easier. After a few rear pad changes, you'll be fixing stripped threads on the uprights, annoying to get fixed.
The studs will help you when replacing rotors too!
Run with TC off to avoid cooking the rear brakes.
SilverLake997 (08-10-2020)
you might also install .2 rear brake ducts while you are at it to increase cooling ...
Best,
Best,
Welcome to 2007 Dell.
And always, no TC!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Help me out here guys. I haven't checked the bolts on my car (997.2 GT3) - are they Grade 10 or some other spec.? What grade are the studs to replace the bolts? Are they intended for multiple uses: removal and reinstallation of the calipers? I agree with Dell about the CLs - total PITA - they take forever to remove and reinstall as well as requiring an understanding wife to stand on the brakes during removal.
996/997 do not use stepped master cylinders like some of the front engine cars. On those the stepped bores of the m/c also affects brake bias.
traction control doesn't affect brake bias at all, it does cause accelerated pad/rotor wear when it is engaged.
