DAS Sport Rollbar Questions
Hi - I just bought a used DAS Sport rollbar (for 996/997) for use in my 997.1 GT3.
When it arrived, it had a few "features" I was not expecting compared with photos from the DASSport web site ... so for anyone who is familiar with these bars, can you answer a few questions ?
First - on the cross bar that the harnesses will attach to, there are the harness alignment fittings welded on - but behind each seat location (between the two harness alignment gizmos) there are a pair of vertical welded on plates with holes. Wondering what they are for ? Is this for bracing a seat back ?
In addition, on the driver's side there is a plate which has been bolted in place with a couple of holes. Again, wondering what this would be for ?
Also at the bottom of the front roll bar, where it is supposed to attach to the B-pillar seat belt mount point, the attachment hardware seems to have had some shims added ... Is that normal / required (eg. is that to spread the load to floor in some manner ?) or was this just a byproduct of a previous install that needed "help" ?
Anyone who has one of these installed, it would be very handy if they could post or PM close up photos of the attachment to the B-pillar (eg. where does the seat belt go - outside or inside of the bar mounting bracket ?). Did you use an eyebolt for harness attach or use something like the BK harness attachment points and a regular bolt ?
Thanks in advance !
Thanks in advance !
Looks like seat brace anchor on 1st pic. If u bolted the the dassport wo those shims u would have a gap underneath- looks like previous owner put those on for a bigger footprint in case of a rollover(if they fit keep them on). If u really want to play safe have someone fabricate shims to bolt and weld to chassis floor but u need to drill holes. Totally forgot how safety belt was mounted- sorry. Mike
yep, plates in the top are for seat brace like this one (the square tube with the holes on the brace fits between the vertical plates in your pic):
http://www.bkauto.com/porsche/r9020.php
i agree with 996FLT6 on the bottom plates...looks like the previous owners setup didnt quite reach the floor.
i have GT2 seats so my OEM belts go directly to that, sorry, have never seen a close up of another type set up. HOWever, i did catch a pic on here somewhere where the guy used an eye bolt to secure the foot pad to the B pillar (instead of using the stock bolt etc). my new DAS bar came with 2 eye bolts but they didnt quite fit into that seat bolt opening so i didnt use them.
Thanks spiffyjiff and 996FLT6 - checking the BK website, the vertical plates are indeed the BK weld-on brackets for a seat brace.
Still not 100% sure what the bolt on plate is for - I'll likely remove it to avoid banging the seat back into it.
I figured thats what the shims were for - I'll have to see how things fit when I do the install in the spring.
